Burned Valve Database DATA ONLY or a P0455 code will be set
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Re: Burned Valve Database DATA ONLY or a P0455 code will be set
Post by E Showell »
Ease up on the throttle in those hills.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
Is there any official Volvo position on these failures?
Or from Bosch since they do the computer, any other cars using the same
engine management having similar problems?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
E Showell wrote: 23 Aug 2017, 08:58 Ease up on the throttle in those hills.
That sucks, that's where I have the most fun! I need to stop "lugging" my car. Heavy throttle in second gear makes the car feel VERY sluggish even though it's obviously revving hard. I really need a tune once I grab a 16t and blue injectors.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Received my Volvo valve stem seals today from Lilse. Two days.
I really credit leaking valve stem seals for most of these failures.
PeteB
Post by PeteB »
Robert, I had Alfa Romeo's back in the 70's and the very early ones had no valve
stem seals, I don't really think that is it. It is possible that if the seals are bad,
then also the guide clearances are wide and then the valves don't seat as well
leading to leaks and then burned valves.
They were all NA and they all had Sodium cooled exhaust valves.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
PeteB's theory makes more sense to me.
Been thanked: 470 times
Post by cn90 »
Just joined the Cylinder #3 burned valve club!
a) Year = 1998
b) Model = S70 GLT
c) Mileage Total = 186K miles
d) Mileage under your ownership = 41K miles (bought it at 145K)
e) Octane Gas you typically use = Usually 89-91. Burned valve happened when my kid drove on highway after filling with Octane 87.
f) Supplier of Gas = Too many different gas stations.
g) Driving Cycle (% city/ % hwy) = 50-50
h) Driving Behaviour (average, passive, aggressive) = conservative, never passed 4000 rpm.
i) Typical Load in Vehicle: single occupant, or multiple occupant = 2 people.
j) Location and Typical driving weather = 4-season with snow.
k) Does the car have leaky valve guides (ie: blue smoke at start up) = No blue smoke but car drinks 1 qt/1000 miles, so I assumed it had a leaky valve seal issue.
l) What kind of oil do you use = synthetic since purchase.
m) Describe in detail how it happened: (ie: ambient temperature, throttle input, load, etc.) = highway at 60-70mph, after filling with Octane 87.
n) How many valves burned and which Cylinder = #3 Exhaust Valve.
o)What brand coolant do you use, when was it last changed = Prestone Green.
p) What did you do with engine = Don't know yet. Probably leave it alone as "Grocery Getter". Whenever I have time, might fix it or donate to refugee families.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Updated Pareto analysis, thanks to all that listed their data. Please try to answer all the questions as it creates a complete picture.
Interesting to note that most failures were with aftermarket coolant as the Volvo coolant has been reportedly designed to reduce hot spots in the engine due to turbo charging. Also interesting to note that none were with aggressive driving owners as the valves apparently rotate over 3000 rpm and therefore may clean the deposits. I occasionally run the car in 3rd gear at highway speed for a minute or two for this very reason!
Need more data to draw conclusions, so keep them coming.
pareto analysis sept 2017.pdf
(91.43 KiB) Downloaded 129 times
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
mecheng wrote: 07 Sep 2017, 10:16 Updated Pareto analysis, thanks to all that listed their data. Please try to answer all the questions as it creates a complete picture.
I wanted to add what my Volvo dealer told me when my 1998 V70 was a couple years old and had hard cold morning start problems. Oh it was a 2.3 hpt auto equipped car. It also in conjunction with the hard starts also had rough idle in gear almost like a misfire. Car under full warranty at time Volvo dealer told me 5 cylinders engines have problems with deposit forming on valves and causes seating problem causing the problems I experienced.
I was instructed by my Volvo dealer service to reseat and remove deposits from the valves to run the car in second on the highway rpm at 5000 for five minutes without interruption and ac off.
Then the valves would reseat. It worked like a charm and the car would idle smoothly and start right up cold for a while.
I noticed car needed it every six months or so. I did a lot of one mile trips per day with that car. I would think it would cause extreme heat and pressure incinerate any deposits during those five minutes.
I have done it to every Volvo since as preventive maintenance about every six months and never had a rough idle or hard cold start or any sort of valve trouble. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
bmdubya1198
June wrote: 07 Sep 2017, 12:24
I wanted to add what my Volvo dealer told me when Mt 1998 V70 was a couple years old and had hard morning start problems. Oh it was a 2.3 hpt auto equipped car. It also in conjunction with the hard starts also had rough idle in gear. Car under full warranty at time Volvo dealer told me 5 cylinders engines have problems with deposit forming on valves and causes seating problem causing the problems I experienced.
In order to receive seat the valves to run the car in second on the highway rpm at 5000 for five minutes without interruption and the valves would reseat. I noticed car needed it every six months or so. I have done it to every Volvo since and never had a rough idle or hard cold start or any sort of valve trouble. June
Interesting notes. Hopefully I won't have anything to worry about, because I have all the checks on the list as far as common things NOT associated with burnt valves... I drive more aggressively, engine is over 4k RPM almost daily, I run Zerex G-05 coolant, which seems to be very close in quality and chemistry to Volvo blue coolant, and I only run 93 octane Top Tier fuel, using either Lucas fuel treatment or Techron at least monthly.
