Random Stalling need advice please :)
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Re: Random Stalling need advice please :)
Post by volvooh »
Good luck. I just pulled my ECU (which I think you are referring to as your body control unit) and sent it to ARD in Oregon along with a donor ECU. I'll post back to let you know how it goes.
get_rocd
Year and Model: 2000 v-70 fwd
Post by get_rocd »
I've been looking into the ignition switch.
Since my issue goes away if I re-seat the key after a stall.
Can anyone tell me if this is a high wear item on my model car, and which part I should look at ordering?
I did just get a brand new key cut and programmed, and I've already Dont the antenna ring. I'd like to not have another key coded if possible.
Thank you in advance to whoever answers this.
I've been driving around for some time now just waiting for this car to quit...
Has thanked: 1503 times
Been thanked: 3817 times
You need the electrical part of the ignition switch.
It has nothing to do with the key or the antenna ring.
Order by VIN number as the parts transitioned during 99-00 model year or remove the old one and pull the part number
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
How old is the fuel pump relay?
Is there a code?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
get_rocd wrote: 07 Sep 2017, 17:27 I've been looking into the ignition switch.
If you have a heavy key chain or a lot of keys then buy a separate key chain and put a single key to the car only and use that in the ignition carrying the bunch of keys separate. This will save your ignition from developing this problem. You likely will have to replace the switch at this point, but the single key won't have weight wobbling back and forth with acceleration and breaking moving the ignition switch slightly causing it to loose contact. I always keep my keys separate from my car key to avoid causing unnecessary wear to the ignition. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
