New Battery - suddenly lots of issues
Shanestrait
Year and Model: 2002 S60
Post by Shanestrait »
A week ago I replaced my battery. It hadn't been holding a charge. New one installed, everything working fine.
About five days after, on the freeway going about 65mph and my car lurches forward, radio cuts out, AC/tach/speedo all cut out, ABS/Parking brake lights come on, but engine continues running. About 30 seconds later everything powers back on like normal except the battery light is illuminated.
It drove fine after that, until in the evening I noticed the lowbeams didn't work although the highbeams did.
This morning it drove totally normal for about a half hour until the AC cut out, car became sluggish at accelerating, power windows were very slow, ABS lights came on...
This is a lot of issues coming all at once and clearly there is an underlying problem here. All I have done so far is disconnect/check the battery and cables twice but it persists. Help is very appreciated!
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
I think your alternator is going out, or your multi-belt is slipping. You may also want to check the alternator pulley. It's a clutch type and the bearings could be worn after 12 years. Use to search function for more information.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
What is your idle v at the battery.
Been thanked: 4065 times
You could be duplicating wisechatmgr and my NY service weekend from the other day...
His alternator went out, killing battery, alternator surge killed low beams but not high beams (DRLs) and a new alternator and bulbs fixed the day.
He also found loose terminals connections in his fusebox.
