S70 still wont hold idle...
If you don't get the 8 second whine , which is the self test, it isn't matched up right. Search Mike's posts (user precopster) for the Guru of Italian Throttle Bodies for more info on this.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Look at the numbers next to the barcodes, your part and version numbers don't match. See the advice about flashing/cloning you ETM
Current Volvos:
Larry_Dean
- Year and Model: 1999 Volvo S70 AWD
I sprayed starting fluid in the intake air temp sensor hole and the car started. Now with the iat sensor back in it will bounce off of the idle. From 800rpm to around 1.5-2k rpm. And it will continue doing this.
- 11 Replies
- 1801 Views
- 1526 Views
Last post by cn90
- 1483 Views
Last post by and1one1
- 1721 Views
Last post by 98v70dad
- 2716 Views
Last post by Eastsidegeorgiaboy
