P2 Clutch pressure plate flywheel release bearing slave cylinder - 2005 V70NAM56 clutch subframe engine drop Topic is solved
Has thanked: 1502 times
Been thanked: 3817 times
Im diving into the clutch on my P2 - 2005 V70 NA
The VIDA has a boatload of special Volvo tools and engine holders for this job
Has anyone done one on a P2 - am I headed for a pig in a poke?
Im not jimmy, but Im a decent wrench turner. Not my first engine out or transmission out.
Im planning on doing it on tall jack stands.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
For the clutch job itself, the UK guys really have the expertise, most of their cars are manual down there http://volvoforums.org.uk/
A touchy job, and not to be done twice
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You need something to hold up the engine and a helper to line up the tranny assy on re-assembly but it's doable
01_Nautic_V70
Year and Model: 2008 XC90 V8
Been thanked: 8 times
Post by 01_Nautic_V70 »
You can use some simple lumber for the bridge to hold and lower the engine.
I used a jack and ratchet strap to raise the trans back into position. Presumably the manual is a fair bit lighter.
There is a lot of kerfluffle about releasing the clutch pressure plate from the flywheel with special tools, not sure if that's a stopper for me
I'm going to do , flywheel, hydraulics , plate, and disc while I'm in there
Searched the UK forum and couldn't find any joy - have a break this afternoon and will try again.
Still haven't made the call on this one. Im 50-50.
Pros
I can do the wheel bearing and evaluate suspension while doing the job
Experience
Abby is home for a week to help
Weather is perfect
Back up at indie I like is three weeks - I can be done before then
We got NOTHING here on MVS and that should be changed..
Cons
Will I mess up engine dropping and get in deep trouble - I guess worst case is push to street and call AAA for clutch failure - is that ethical/Moral or does that make me Martin Shkreli?
Stealing 2 hours a day from spouse on weekend
(on edit by Ms Dr Abscate - this should be in the Pros column)
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Are these the instructions you saw in VIDA? (auto trans shown but probably much of it is pertinent to your manual trans.)
http://www.v70xc.com/0/resources/how-to ... Remove.pdf
http://www.v70xc.com/0/resources/how-to ... nstall.pdf
Maybe you can fabricate an engine hanger (truss).
jbeebo
Year and Model: S60, 2005
Been thanked: 3 times
Post by jbeebo »
did you see the truss that Nautic rigged up? Nicely done.
viewtopic.php?f=9&t=75588&p=447534&hili ... ck#p447879
2005 S60 2.4L (B5244S6), 175k miles
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
A hack like me did one not long ago, so you'll be fine. I recall that a ratcheting come-a-long (or two) was extremely helpful in maneuvering the hunk of metal. It is however much lighter and smaller than an automatic trans.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
Well, I think I may have really driven this bad clutch past prudent practice.
I'm dropping the subframe, and all the pieces of the release bearing are pouring out of the week hole.
Lots of little ball bearings
