Severe oil leak on S70 glt
RDR89
Year and Model: 1998 S70 GLT
Post by RDR89 »
I located where the oil is leaking from but do not know what I am looking at. It is not the turbo seals. It is coming from a white plastic looking gem five inches forward from the turbo seals coming out of the engine way up there above the front axel.
I am sure this is an easy question for experienced Volvo wrench turners. My first Volvo so any help to get this silver beast going is very appreciated.
Thanks, Brian
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Inside the red circle is the coolant tube and coolant hose.
This is the back side of the engine, are you sure the the valve cover is not leaking? There is not much in the back of the engine.
There's the camshaft seal on the side, turbo, oil feed and oil return to the turbo, and the valve cover that can leak oil.
85 GLH, 367 whp
00 Insight, 72 mpg
RDR89
Post by RDR89 »
Ok, I suppose the leak could be coming down from the valve cover. I am letting the heat shield cover bolts soak over night so I can get a better look tomorrow weather permitting.
I thought the turbo gaskets were where I have the green circle.
It looks like it is coming out of that place I have in the red circle. Really drips when it is running. I see what you are saying. Hard to tell from looking straight up.
Has thanked: 1609 times
Been thanked: 4064 times
You've got the turbo seals right, in green.
I'm not sure what that item is, I'll try find a better picture of the engine for reference
RDR89
Post by RDR89 »
Thanks!
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
Is that a banjo bolt?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
The pipe circled in green is the turbo oil return. That gasket leaking is pretty common. If you replace that, make sure you replace the o-ring on the end that goes into the block.
Can't tell what that is in red. I'm not aware of any oil lines in that area.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
It is my opinion that the cam cover (they do not have valve covers) on these do not leak. If it is leaking, it's been leaking since installed.
If the leak is on the drivers side, higher than the axle, it is likely a rear cam seal.
bmdubya1198
It's actually very likely a cam seal is dripping down, totally forgot about that. Got caught up in where the picture was taken. Check around the cam sensor and distributor cap for oil.
RDR89
Post by RDR89 »
Thank you for the comments and videos with Robert. Looking at the passenger side there is oil build up and on the side as well. So looking at the cam seals now as a possibility. I am cleaning it now.
Brian
