YIKES!! 15 Qts. of oil to get home tonight Topic is solved
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
My wife was driving the car this afternoon when my daughter noticed the warning light telling her low oil pressure and to shut off the engine. I went out to swap cars and took enough oil with me to add a quart every 3 miles and I made it home safely. So, it's pitch dark here but with a flashlight the timing belt is soaked and it's leaking around the base of the crankshaft sprocket or there abouts. I really have no idea until I dig in there tomorrow morning but is there anything particular that I need to focus on that could dump this much oil out in such a short amount of time? It's possible that this has been a small leak that suddenly got worse today but my driveway doesn't really show much pooling of oil. I'm just glad that the idiot light came on and that my daughter caught it in time!! She gets a movie and ice cream tonight!!
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
tryingbe
- Year and Model: None
- Been thanked: 26 times
Sounds like either cam shaft seal or crank shaft seal is leaking. Your PCV system probably is clogged and blowby pushed the seal out.
You'll have to take the timing belt off. I'd check the PCV system, get oil OEM seals, and change the timing belt.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
aaron1611
I did a full PCV replace a couple of months ago. changed the oil/filter about a month ago. I changed the Siren Module 3 weeks ago and I didn't notice anything unusual. My indie shop is closed on Sundays but I'll tear it all down and see what I'm looking at. The timing belt was changed about 15K miles ago, the odom reads 119K currently.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
It either was not done properly, or the seal was already almost pushed out just before PCV was done. Healthy PCV still allows pressure spikes when it switches from intake manifold to turbo inlet pipe, plus piston rings could be partially stuck and the sump sees lot more blow-by gases.aaron1611 wrote: 16 Sep 2017, 20:13 I did a full PCV replace a couple of months ago. changed the oil/filter about a month ago.
aaron1611
So, got the timing belt cover off, front passenger tire off and sprayed brake clean everywhere and it appears that the leak is from the crankshaft seal. I see how to align the timing belt to the notches on the cover and making sure it aligns down below at the crankshaft. It looks straightforward to remove timing belt and get the pulley rental tool at the auto store but is it necessary to order that special tool to lock the cam shaft in place? I've read where you can make one yourself but as long as neither cam moves I should be good?
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
got serpentine belt off and bottom pulley but i sprayed so much brake clean the crankshaft sprocket looks nice and dry which makes me doubt myself that this indeed was the leak. will get the timing belt off and sprocket and check back.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Regarding the cam locking tool.....I've read posts claiming both TOTALLY necessary and COMPLETELY unnecessary.
I was able to use stout string to tie my camshaft sprockets in an immobile way because I saw that there were holes in the sprocket at usable 9 and 3 o'clock positions. "Your sprockets may vary".
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Sure you can lock the sprockets easily but the cams aren't locked or keyed to the sprockets, when torquing the cam sprocket center bolt the camshaft can and will turn. That center bolt is around 80 foot lbs and it will slip unless locked at the rear of camshaft.
Amazon has cheap knockoff locking tools that get decent feedback.
aaron1611
i have it all apart oil pump off but i have a question, is there supposed to be play in that center ring with the teeth on the pump? there is quite bit of movement with that center sleeve. Ideally, would like to confirm this prior to putting it all back together. ALSO, the crank seal was intact and had not popped out. Green gasket looked rough.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- 13652 Views
Last post by oragex
- 37 Replies
- 10492 Views
- 976 Views
Last post by precopster
- 1124 Views
- 3125 Views
Last post by cn90
