Current stats, average new car owned about seven years, average used car owned 5 years
Average age of cars on road in U.S. Is 11.6 years -all time high.
A 10 year old car is newer than average!!
07 XC70: broken suspension coil spring, shop wants $3K. Help?
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
At 16 years old, my 2001 V70 is just 4 years from classic car status!
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Isn't it counted from the end of production, which is 2007?01_Nautic_V70 wrote: 19 Sep 2017, 07:58 At 16 years old, my 2001 V70 is just 4 years from classic car status!
vtl
As an owner of a new Volvo (wife's), I don't want a new Volvo for myself. Maybe I'm already too old (still under 40), but I want a car, not a poorly made motorized iPad.abscate wrote: 19 Sep 2017, 04:37 Current stats, average new car owned about seven years, average used car owned 5 years
01_Nautic_V70
Oops. In my state any car over 25 years old can get Antique plates. So I have 9 years to go, not 4.vtl wrote: 19 Sep 2017, 08:10Isn't it counted from the end of production, which is 2007?01_Nautic_V70 wrote: 19 Sep 2017, 07:58 At 16 years old, my 2001 V70 is just 4 years from classic car status!
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
My wife's 2004 Volvo XC70 L/F coil spring broke about 18 months ago. It was the original spring that came with the car, had over 160k on the odometer. I replaced both front coil springs and everything else while I had her apart. New front struts(Sachs), strut mounts, strut bearings, spring insulators, cross nuts, ect. and also did tie rod ends, sway bar links. LCA's /lower ball joints werre good so I just applied some sylglide to LCA bearings rubber. Any way the coil springs were made by a German manufacturing company that makes them for Volvo, I can't remember the name off hand. So 18 months later the L/F coil spring broke just like first spring. A three inch piece that sits in the lower spring insulator.oragex wrote: 15 Sep 2017, 17:03 The springs are back ordered at the main dealer because the XC70 has a tendency to break them. I have read more than one owner who replaced one, then a second failed months later. And you may be unlucky and have it break on the road, quite unpleasant not to mention not safe. Do you have to absolutely replace both at once ? NO. You risk having one spring lower than the other one, but there is absolutely no reason to replace both springs at once. What is really important to replace at all corners on the XC70 is all 4 tires, because of the AWD - but that's another story. To my knowledge, no need to replace anything else (shocks, brackets, etc) but the broken spring. By the way - strut in the front and shock absorber in the rear.
You may type local.google.com and search a garage who does european cars
That said, the rear springs are harder to replace, so more time to do this job.
Speaking of broken springs, almost all on the XC70 I've read about had the front ones break. So do a close inspection for deep rust at all 4 corners.
For us is hard to figure what 'broken at the very broken' really is - maybe a picture? I had front broken springs on a Honda, the very last half coil at the bottom was broken on both sides, never realized until I had to replace the tires.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
