Outer Tie Rod
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Outer Tie Rod
Working on the suspension of the project car I picked up. It's a 1998 S70 and the outer tie rods are original. I released the ball joint fairly easily, but I am having a hell of a time separating the outer tie rod from the inner tie rod. Sprayed a lot of PB blaster on the joint, but it's difficult to keep it steady since I removed the ball joint. Any suggestions or advice would be greatly appreciate.
No, the lock not is still on there.
- Has thanked: 138 times
- Been thanked: 374 times
I agree: reattach the ball joint, heat and cool the lock nut until you can break it loose. Remember you can often break it loose by trying to tighten it, too. If you can, set up opposing wrenches on the inner and outer tie rod close together, so you can squeeze them toward each other to try to free up the nut.
Once the lock nut breaks free you may be relatively home free for unscrewing the outer tie rod. But you do have Chicago rust to contend with ...
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
130k
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 42 times
or you can be proactive and replace the inner and outer as an assembly. (not cost effective if unnecessary, but ya know)
Current Volvos:
Thanks for the advice. I reattached the joint and tightened the lock nut. The lock nut didn't budge but it separated from the tie rod, which made it then easier to remove. The good thing is the lock nut stayed in the same position so I didn't have to worry about positioning. I measured it though after installation of the new one and it was spot on.
