Torque Axle Nut
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
With a fine syringe that would be possible. Great thinking there!!
Has thanked: 2202 times
Been thanked: 1852 times
I have done that to prevent all the grease scooting out when trying to fit the boot clamps. You have to work the CV joint or the grease gets pressure locked in the joint.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
precopster wrote: 21 Sep 2017, 06:50 With a fine syringe that would be possible. Great thinking there!!
Not for this, but I used a small tubing with a 20ml medical syringe to grease another item (forgot what it was). It is a slow process however, and it gets messy. And you can't do the same on the transmission side joint.
What I have done with my CV joints, is using the tip of a cutting pliers to bend the 'u' portion of the Oetiker clamp open until the clamp released, then clean all the old grease inside and put about 1/4 cup of lithium/molybdenum grease
http://i1.adis.ws/i/washford/634949?w=637&h=403
I then used a lighter Oetiker clamp to close the boot with some chinese clamp pliers because the original clamp is impossible to close back again.
Has thanked: 311 times
Been thanked: 817 times
oragex wrote: 21 Sep 2017, 08:33 ...
Are you talking about changing CV grease as a routine maintenance task? I never have, but I could see you may consider it if the boots are long-lived. I have only changed out the CV grease when a boot has cracked.
