Torque Axle Nut
- Year and Model: Lots
- Been thanked: 128 times
With a fine syringe that would be possible. Great thinking there!!
- Has thanked: 2197 times
- Been thanked: 1850 times
I have done that to prevent all the grease scooting out when trying to fit the boot clamps. You have to work the CV joint or the grease gets pressure locked in the joint.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Not for this, but I used a small tubing with a 20ml medical syringe to grease another item (forgot what it was). It is a slow process however, and it gets messy. And you can't do the same on the transmission side joint.precopster wrote: 21 Sep 2017, 06:50 With a fine syringe that would be possible. Great thinking there!!
What I have done with my CV joints, is using the tip of a cutting pliers to bend the 'u' portion of the Oetiker clamp open until the clamp released, then clean all the old grease inside and put about 1/4 cup of lithium/molybdenum grease
http://i1.adis.ws/i/washford/634949?w=637&h=403
I then used a lighter Oetiker clamp to close the boot with some chinese clamp pliers because the original clamp is impossible to close back again.
- Has thanked: 311 times
- Been thanked: 817 times
Are you talking about changing CV grease as a routine maintenance task? I never have, but I could see you may consider it if the boots are long-lived. I have only changed out the CV grease when a boot has cracked.oragex wrote: 21 Sep 2017, 08:33 ...
- 14930 Views
Last post by raymidd
- 751 Views
- 1070 Views
Last post by zombielinux
- 483 Views
- 461 Views
Last post by erikv11
