Just bought a 2003 XC70 for a great price. Needs a radiator, T-stat, maybe head gasket.
It seems that from 2002 forward the T-stat and housing is a self-contained built- unit with sensor and t-stat and the entire unit has to be removed.
Soooo its not just pull the t-stat like earlier models. So does the PS pump have to be moved or removed to take that housing off on a 2003 XC70?? Are their any short cuts or cheats which anyone figured out... to the t-stat replacement?
I could not find a tutorial for this repair. Thanks for any tips or advise.
2003 XC70 - Project
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
In theory this should fit
http://www.ebay.com/itm/Thermostat-de-t ... SwB-1YqNrV
If not this
http://www.ebay.com/itm/Engine-Coolant- ... wy&vxp=mtr
We toss (don't disconnect) the power pump then use a u-joint on a 1/8" drive to access the lower housing bolts
If not this
cuhfs
Thanks. I will check that out after I get the part out. thanks I just saw this "We toss (don't disconnect) the power pump then use a u-joint on a 1/8" drive to access the lower housing bolts".
When you say toss you mean move to a side?
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
We need the Aussie translation guide
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
On my - 04 the second one is the right one. To replace it I couldn't see how to do it without removing the PS pump. I just disconnected the pipe but not the hose and moved it aside. There was very little oil leaking out when I did so.oragex wrote: 21 Sep 2017, 21:10 In theory this should fit
If not this
I've heard that you're supposed to be able to fit the old thermostat housing instead to make any future replacements easier and cheaper. If I'd had an old one handy I would've gone for that option myself.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Buy Gates t-stat from UK or the whole housing locally here ,but replace t-stat only. No reason replacing the housing if nothing is leaking.cuhfs wrote: 21 Sep 2017, 20:55 Soooo its not just pull the t-stat like earlier models. So does the PS pump have to be moved or removed to take that housing off on a 2003 XC70?? Are their any short cuts or cheats which anyone figured out... to the t-stat replacement?
- Year and Model: Lots
- Been thanked: 128 times
In an Aussie mechanic's workshop "toss" means to throw out
So when you are cleaning your garage are you a tosser??
Yes I throw a lot of things out.
If you don't want to offend others or if you don't know what any of those words mean, don't use them.
- 30 Replies
- 5598 Views
Last post by jimmy57
- 9 Replies
- 642 Views
Last post by Lyri
- 1108 Views
Last post by precopster
- 10 Replies
- 2293 Views
Last post by 90 Beater
- 487 Views
Last post by Ozark Lee
