Brake Booster Check Valve Hose Question
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
Hello All! From brake booster/check valve on the turbo cars, where does the other end of the booster vac hose terminate/ connect to and also, why is such a cheap little plastic check valve/grommet so damn expensive at 50.00 plus dollars??? Thanks!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Assuming yours is like mine - it works through venturi effect of pressure passing past it at a designated rate, creating a vacuum, similar to the cheap fertilizer injectors that were long ago used at residential properties.
Mine is black and about 2-3 inches long. It has one connection to intake manifold and two out - one of which to brake booster.
Why on the price? It is Volvo. That part may only need to be replaced every 15-20 years - if ever. When you figure the cost per mile it is likely costing you less than what you are likely to pay for a single bar of soap on a yearly basis.
- Has thanked: 311 times
- Been thanked: 817 times
warmblood58 the junkyard is your friend on this one, I have not seen those go bad and wouldn't hesitate to get a used one and save about $48.
- Has thanked: 2197 times
- Been thanked: 1851 times
They do go bad but not a common issue. /but like the guys say, the one that went out on me was 16 years and 165,000 miles on it.
Junkyard is your friend. Usually went I pull them at PnP I have pulled other parts and they don't charge me for them.
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Thank you for the description wizechatmgr. What are the symptoms when this check valve fails? All three of my turbo P80 s have this valve but I have never given this valve any thought.
- wizechatmgr
Likely an increase in the amount of pressure having to be applied to the brake pedal.
If the check valve isn't working, the problem will be air gets into the master cylinder. So the usual symptoms there: hard pedal (excess pressure in the master cylinder), or soft and spongy pedal with reduced braking in response to pedal travel (air gets into the brake lines).
warmblood58
Thanks all, yea, I was thinking about picnpull as I drifted off to sleep
warmblood58
Thanks all, yea, I was thinking about picnpull as I drifted off to sleep. When I go, I usually pull other parts along with certain bolts, clamps, nuts and other hardware -
- 1836 Views
Last post by thylacine222
- 9 Replies
- 4034 Views
Last post by ndphotonl
- 1611 Views
Last post by walter1
- 13 Replies
- 7045 Views
- 4871 Views
Last post by todda
