P2 Clutch pressure plate flywheel release bearing slave cylinder - 2005 V70NAM56 clutch subframe engine drop Topic is solved
- Has thanked: 2857 times
- Been thanked: 1332 times
In for a penny, in for a pound.
- Year and Model: Lots
- Been thanked: 128 times
Not totally sure if it's too late but you could have rigged up some subframe hangers which are no more than M18 threaded rod with adjustable nuts and washers in place of the 4 subframe bolts. I fabricated a set in my workshop with a welder....saves subframe removal.
- Been thanked: 4068 times
I could still do that, Mike, but I'm not sure of that really saves me that much work over just dropping it?
I still have to do all the disconnects.
Update today.
Elapsed so far
1 hour spent gathering tools, info, putting engine bar together
2 hours disconnecting, draining, and removing steering knuckles and driveshaft
Today
1 1/2 hours dropping subframe - this is a Southern car so things were really good rust and corrosion wise.
I found two connections not documented in VIDA - both on the front top of subframe, M6 bolts holding PS tube and ground cable - both obvious
The sub frame is not heavy - maybe 100 pounds total? Easily moved by one person, and easily lowered in stages by hand onto blocks while watching for things hanging up.
VIDA cautions to make sure the steering rack threads clear the subframe - mine did without intervention.
Prognostication
Another 2 hours to get the engine dropped, trans out, and clutch/seals sorted
Another 2 hours to reinstall
Another 1 hour to finalize.
Total - 9-10 hours. Pretty much on the book, but Im doing this on my back, whereas the book is on a lift. I could save a lot of time on a lift with the jacks and tools Volvo has. I would guess a 6 hour job.
Also replacing
Rear engine oil seal
Clutch slave
Release bearing
All cooling hoses
Noisy right front wheel bearing
Lots of pictures to come
Elapsed so far
Today
Prognostication
Also replacing
Clutch slave
Release bearing
All cooling hoses
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
While there, the lines at the steering rack can rust and leak, the downpipe flexible starts leaking after 10 years, sway bar bushings to frame get worn
Now I'm reading VIDA a jaundiced eye and sure enough the " 7 bolts holding engine and trans together look like this ....
Captions are all messed up, sorry...will fix
You don't want the PS rack flopping around when you drop the subframe
VIDA makes reference to a fancy flexible retractor - I tied the pass side of the rack to the engine lowering bar, making sure you don't go through the sway bar, and then put a jack stand under the other end of the rack to keep it from flapping in the breeze.
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Wow that's progress! Nice!!!
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
YYYYEEEESSSSSS!!
cuhfs
Smooth sailing from their!
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
