S40 CPS code PO339
wilsonrcjr
- Year and Model: 2002 S60
I rebuilt my daughters S40 non turbo 2005. When restarted it will run for 10-15 seconds and stall. Codes intermittent Crankshaft position sensor. I replaced the sensor, & the connector. I sent it to a repair shop and they had problems communicating with the computer and told me to take it to the Volvo dealer. After 5 hours of diagnostic fees, they said it needed a computer and or flywheel. So, I brought it home and had Xemodex redo the ECM and I put in a new flywheel. There is no change, cranks, dies. The Volvo mechanic and I both checked the harness - there is continuity at the ECM pins for the CPS. Any ideas would be appreciated.
wilsonrcjr
I replaced the engine wiring harness today - still no improvement
runs for 10-12 seconds and codes crank sensor
any ideas would be appreciated.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Make sure the battery is not weak...strange things happen with our cars when they are.
- 9 Replies
- 1777 Views
Last post by erikv11
- 855 Views
Last post by kahl
- 726 Views
Last post by cn90
- 1615 Views
Last post by RickHaleParker
- 3033 Views
