I'm scared to death of putting sealants like that anywhere near my car. I've heard so many mixed reviews I don't even know what to believe anymore.PeteB wrote: 30 Sep 2017, 14:54 I was very surprised to find this, and that it sometimes works. I'd think
that with the stress of a turbo it would not hold up:
Attempting to diagnose a possible blown head gasket! Help!!
Aintezbeincheesy
- Year and Model: 1994 850T
- Has thanked: 2 times
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
My view on sealants is this:
Do you plan on keeping the car for any length? If so, I wouldn't use the sealant.
Do you plan on junking the car? If so, try the sealant, at that point you're getting borrowed time if it works.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Yes, the oil cooler for your car is in the radiator tank. It is possible, but probably less likely than a HG failure.Aintezbeincheesy wrote: 30 Sep 2017, 14:11 Crossing my fingers that there could be ANY other way for oil and coolant to mix.
That said, yeah, do it yourself, use the tracy's truesoaps tutorial found in the database, and you need to check the head first. the tolerance is pretty tight, so most likely, it will need to be trued. But you'll save a lot on labor!
Current Volvos:
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
First, before you start your drive, have you checked your coolant level? If full, I would replace the thermostat immediately with the proper VOLVO stat.
Second, if the temp tries to raise after that, replace the water pump the very next day. I have seen the impeller fall off of the water pump shaft.
If you have ANY coolant leaks, fix them.
PeteB
- Year and Model: 1996 Volvo 850 Wagon
- Has thanked: 57 times
- Been thanked: 11 times
Yes, I agree only try it as a last resort should have said this.wizechatmgr wrote: 30 Sep 2017, 15:45 My view on sealants is this:
- Has thanked: 311 times
- Been thanked: 817 times
Use sealant only as part of the disposal process, if you want to see if you can run it even though you are throwing it away. Those products are not related to trying to fix it.
Aintezbeincheesy
[background=][/background]
Thanks Robert! Love your videos. Got me through a pcv system replacement relatively painlessly. Will make replacing the thermostat my next move!rspi wrote: 01 Oct 2017, 20:56 First, before you start your drive, have you checked your coolant level? If full, I would replace the thermostat immediately with the proper Volvo stat.
- 527 Views
Last post by Sveedy
- 1202 Views
Last post by Broodoobob
- 953 Views
- 1330 Views
Last post by lummert
- 1098 Views
Last post by cn90
