I got a new wheel bearing from FCPp, who I consider trustworthy, but it feels hard to turn and a bit notchy. Car is a 2000 V70 fwd.
Any opinions?
Thanks
Feld
New wheel bearing feels notchy
- Been thanked: 4068 times
Feld...it's really hard to tell a new from old bearing bybfeel. I'm just putting anew one on my 2005 and it doesn't even spin by hand, the resistance is quite stiff
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Resistance is ok on a new one as it will feel somewhat tight. But the 'notchy' bit may not be ok. That might imply a defect of either a bearing or race that wasn't caught by QA. You might call FCP customer service. Describe what you're feeling and see what they say. They may say that's normal for a new one but I doubt it.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
A new one should be stiff & tight. It shouldn't be notchy or make any noise when rotated. If you have access to a stethoscope you can listen to it. You can also put your ear to a large screwdriver and put the other end on the bearing body. Or use a piece of tubing to listen to it.
I rejected a TB idler pulley (INA fake) because it rotated too easily and grumbled. I also rejected a Mahle A-arm because the ball joint wasn't smooth and moved to easily. I went with Lemforder because they were very stiff and well greased.
M1 10W-30 HM
M1 10W-30 HM
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, if it grabs, even a little, return it. It can still work, but it means it has already an issue as new or it's a really crappy quality - i.e. it won't last
- 10 Replies
- 1914 Views
Last post by tryingbe
- 3102 Views
Last post by oragex
- 1955 Views
Last post by oragex
- 2896 Views
Last post by smacknab
- 1175 Views
Last post by precopster
