P2 manual transmission M56 reinstall
Been thanked: 4065 times
Managed to do this in 15 minutes.
I used an Al racing jack with a wood plank, and I kept jacking it up until the top two bolts were level, the tipping the back up,and blocking it until I finally had a level transmission and top bolt holes aligned
I then put in two over length M12x1.5x 90 bolts and threaded them into the block about 6 threads.
I then carefully advanced the transmission until the splines met, a little wiggle on the flywheel teeth and they meshed, and then ....clunk....the trans slid home to the block.
Cardboard on the driveway helped the jack move both in/out and sideways as needed
Abby had a role up top as a safety in case I wiggled off the wood braces
Elapsed time from roll in to bolt up , about 45 minutes.
Alignment bolts in place
Ps....hockey pucks are great for blocking up the transmission..I drove up to Toronto and found a bunch in the Leafs net...
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Nice job.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Great job, Steve. Did you end up converting to a single mass flywheel? If yes, is there anything different in terms of installation?
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
