Threading's the only way here. You could adapt a large threaded plumbing cap I suppose.....large thread taps and drill bits are insanely expensive though.
AW55-50SN woes-easy to repair? Topic is solved
Repairing a AW55-50SN Transmission in a 2001 V70
- Year and Model: Lots
- Been thanked: 128 times
A rubber plug won't hold 6psi of fluid pressure.
Threading's the only way here. You could adapt a large threaded plumbing cap I suppose.....large thread taps are insanely expensive though.
DOUBLE POST ALERT- MODERATORS PLEASE DELETE.
Chitty chitty bang bang
Another 60kms
Another 60kms
- IMG_20171004_225813-768x576.jpg (58.06 KiB) Viewed 2688 times
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Hold 6psi of pressure? You wouldn't be running the engine with the plug/ultrasonic element in place. You'd be letting it sit overnight.
If the piezo element is powerful enough it could conceivably just be stuck through the existing OE provided drain hole. However, without making a new threaded hole directly under the filter inlet the issue reverts back to how to get the junk that broke free from the ultrasonic cleaning out so that it doesn't just get sucked back into the filter screen again.
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
Set your clock already! Ready to do a new adaptation on it yet? Magnefine filter(s) in place yet?
The factory drain plug is only 4.5 inches from the hole I drilled. The fragments would flow toward it.
Besides as I explained using the upper cooler hose as a fill point can allow you to pour a solvent straight into the sump to help push things along toward the drain plug.
Are there piezo elements that can fit into an 18mm hole? The wires could pass through the rubber grommet. Then fill the sump via the upper cooling hose with ultrasonic cleaner like freon or similar. Only question that remains is whether 3.5 litres of fluid would reach the filter element. The sump may need to be overfilled by 2 litres or more so the ultrasonic waves can pass through the filter medium.
Nautic filter is not here yet. No more driving until it's in place.
Adaptation wouldn't hurt. Pretty good without it though....
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Just an idea, what about welding a bung on the case before drilling it, that would provide enough meat for a threaded drain.
Or some sort of butterfly bolt/plug that spreads when tightened.
01_Nautic_V70
I'd be surprised if you could get a good weld on that area without removing the bellhousing and flushing the area. Welding on it in place would result in burning off some ATF. Trans fluid is generally a specialized hydraulic oil, so I'd be very concerned about that and the residue/smoke left in the transmission.jonesg wrote: 05 Oct 2017, 04:45 Just an idea, what about welding a bung on the case before drilling it, that would provide enough meat for a threaded drain.
Can't believe nobody mentioned these Magnefines are made here!!
It arrived yesterday and will be fitted later today. Finally we have our tow car back as T5 is the only one with a hitch.
- IMG_20171007_110328-600x800.jpg (55.44 KiB) Viewed 2482 times
- 11 Replies
- 4458 Views
Last post by precopster
- 1810 Views
Last post by BEJinFbk
- 16 Replies
- 14886 Views
Last post by vt9000cse
- 1687 Views
Last post by dadyer
- 1121 Views
Last post by matthew1
