Attempting to diagnose a possible blown head gasket! Help!!
Aintezbeincheesy
Year and Model: 1994 850T
Has thanked: 2 times
Post by Aintezbeincheesy »
PeteB wrote: 30 Sep 2017, 14:54 I was very surprised to find this, and that it sometimes works. I'd think
that with the stress of a turbo it would not hold up:
I'm scared to death of putting sealants like that anywhere near my car. I've heard so many mixed reviews I don't even know what to believe anymore.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
My view on sealants is this:
Do you plan on keeping the car for any length? If so, I wouldn't use the sealant.
Do you plan on junking the car? If so, try the sealant, at that point you're getting borrowed time if it works.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Aintezbeincheesy wrote: 30 Sep 2017, 14:11 Crossing my fingers that there could be ANY other way for oil and coolant to mix.
Yes, the oil cooler for your car is in the radiator tank. It is possible, but probably less likely than a HG failure.
That said, yeah, do it yourself, use the tracy's truesoaps tutorial found in the database, and you need to check the head first. the tolerance is pretty tight, so most likely, it will need to be trued. But you'll save a lot on labor!
Current Volvos:
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
First, before you start your drive, have you checked your coolant level? If full, I would replace the thermostat immediately with the proper VOLVO stat.
Second, if the temp tries to raise after that, replace the water pump the very next day. I have seen the impeller fall off of the water pump shaft.
If you have ANY coolant leaks, fix them.
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
wizechatmgr wrote: 30 Sep 2017, 15:45 My view on sealants is this:
Yes, I agree only try it as a last resort should have said this.
Has thanked: 311 times
Been thanked: 817 times
Use sealant only as part of the disposal process, if you want to see if you can run it even though you are throwing it away. Those products are not related to trying to fix it.
Aintezbeincheesy
[background=][/background]
rspi wrote: 01 Oct 2017, 20:56 First, before you start your drive, have you checked your coolant level? If full, I would replace the thermostat immediately with the proper Volvo stat.
Thanks Robert! Love your videos. Got me through a pcv system replacement relatively painlessly. Will make replacing the thermostat my next move!
