convince me it's worth fixing my headlight wipers (98 S70) Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
I plug the washer line when I remove the wipers.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
New? They've been making these since '85!abscate wrote: 06 Oct 2017, 23:33 Just remove one of them and then tell people one-wipered cars is a new thing.
Actually, mine has headlight wipers too...and they're broken. Surprise surprise.
- Has thanked: 1611 times
- Been thanked: 4071 times
I fixed mine with yellow zip ties because I ran out of pink ones -
- Has thanked: 2207 times
Biggest issue with these is the overload resistor failing with time. If we could find a source of those square thick film (or whatever they are called) resistors then fixing them would be fairly easy. After so many years they need a service like most other parts of any car using grease, and a fresh amount of grease, new resistor and off they go again. Most of us would only have to do the job once in the cars' lifetime (or is that our lifetime?). I use the copper wire replacement, but need to look again at the in-line fuse to prevent blowing the main fuse which takes the main wipers out and some other stuff.
If you don't need them as the headlights don't get too bad when driving year around I wouldn't bother. Here in winter they are handy to have in snow and dirty roads we get, but even I have doubts on their use.
- utilityaudio
- Year and Model: '98 S70 GLT
- Has thanked: 36 times
Thanks everyone, sounds like a pretty unanimous chorus of "don't bother"
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
2023 Lexus RZ450e -66k
- 10 Replies
- 2266 Views
- 22 Replies
- 12816 Views
Last post by j-dawg
- 2841 Views
Last post by eapowers64
- 26 Replies
- 4806 Views
- 1045 Views
