I understand this is an old (but very good) post.
I have a very specific question: does this Idle Valve ever goes bad that needs replacement?
I have been cleaning my Idle Valve every 50K, and have zero issues, but the other day I was at the junk yard and saw a newish looking Idle Valve, I am tempted to salvage it for later use, but if the forum tells me this part virtually never goes bad, then I'd not bother removing it from the junk yard car.
P80 Idle Control slide or IAC 9454745 Cleaning
P80 Idle Air Control (IAC) Cleaning
Great write up - thanks for the info!
cn90 - I would guess that the only time this valve would be bad/need replacement is if you are getting a code relating to the IAC valve. No idea if that's common or not; sorry.
Paul-93-850
- Year and Model: 1993 850 non-turbo
Wish there was a photo of the "rubber elbow on the passenger side end of the intake manifold"
- Has thanked: 1613 times
- Been thanked: 4077 times
Im sure there are pictures in the VRD under PCV repair, maybe?
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Here is an image of the elbow, broken.
- elbow.JPG (83.14 KiB) Viewed 4465 times
Paul-93-850
Nothing showing there on my 1993. Did you take anything off to get that photo?
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
There is no nipple on the intake manifold on the 93's or 94's (all?). On my 94 the vacuum line from the air intake hose was connected to the vacuum tree.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
Quicken
- Year and Model: 850GLE-96
- Has thanked: 3 times
Hi there
I have spent a bit of time researching about the IAC valve and watched a few youtube videos and looked up parts on amazon etc...everything was rosy until I opened the cover...to my confusion, I couldn't find the IAC valve or anything that looked like it? Shouldn't it be a shiny round bottle like structure with 2 big tubes connected to it. I looked again and found a small round bottle like black structure with 2 small tubes connected to it. Nothing like 50+ or so pictures that I see on the internet.
I have a 1996, 850 GLE 5 cyclinder 10 valve 4 dr base model.
My Idle air control valve looks like this below: My question is that is my IAC valve cleanable? If not, where can I buy one? Dealership says Volvo don't make them anymore and I searched around a bit and couldn't really find one either.
Thanks a great bunch!
Quicken
Quicken
Teddy1975
- Year and Model: 2007 V50
- Been thanked: 7 times
It's the same I have problems with on my car. I haven't yet fixed mine, but my trusted Volvo mech told me to disconnect the two hoses from the IAC and the wiring, remove the IAC from the car, pour rubbing alcohol into both ends and block them off while you give it a vigorous shake. Empty the IAC and repeat 5-6 times. Do not use compressed air or something harsher than rubbing alcohol as the valve in it is supposedly quite fragile.Quicken wrote: 14 Dec 2017, 02:40 My question is that is my IAC valve cleanable? If not, where can I buy one? Dealership says Volvo don't make them anymore and I searched around a bit and couldn't really find one either.
Quicken
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
- Has thanked: 312 times
- Been thanked: 818 times
That's an interesting point. I've always cleaned them out with carb cleaner but maybe it's better to use something milder, e.g. rubbing (isopropyl) alcohol.
- 10 Replies
- 1849 Views
- 865 Views
Last post by a73s
- 680 Views
Last post by turtle1615
- 1616 Views
Last post by Volvo Manic
- 1012 Views
Last post by misha
