93 Volvo 850 MT Will opening rear brake line drain clutch reservoir?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I'm considering replacing a rear brake hose and assume I'll lose all the fluid from the reservoir. Will the clutch fluid level also drain?
LOB
Year and Model: 855 GLT 2.5T
Has thanked: 10 times
Been thanked: 16 times
Post by LOB »
By pushing down the brake pedal 3/4 of maximum (with a plank between the seat and the pedal if you are on yourself) you will only lose a few centiliters of break fluid.
Been thanked: 4065 times
You won't drain much, Jim. just put some tape or a rubber glove on it and you will be fine
LOB
Post by LOB »
abscate wrote: 12 Oct 2017, 05:03 You won't drain much, Jim. just put some tape or a rubber glove on it and you will be fine
Or, if you don't want to mess with break fluid at all (except for a few drops) you do it the way I suggested (no fluid can escape the master cylinder when the break pedal is in 3/4 position)....
See this illustration:
http://www.agcoauto.com/content/images/ ... utaway.jpg
If you did drain the reservoir you wouldn't have to do anything with the clutch. The hose to the clutch cylinder would stay full and when you topped up it would burp the air
That's a nice tip from LOB to close of the mc ports!
JimBee
Post by JimBee »
Thanks, both, for the good news, but I'd like to understand the logic better. Why doesn't pressurizing fluid at the outlet create more pressure throughout the lines with major fluid loss if a line is opened?
You will squirt out a bit when you crack the line, but then the pressure is relieved and the fluid will just seep a bit
What LOB clever trick does is block the 'refill ports' in the master cylinder, which prevents the reservoir from draining into the mastercylineder and out the wheel area.
Does that make sense?
JimBee
Post by JimBee »
Makes sense. Thanks!
