Do You Really Use Torque Wrench?
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Hello folks, am just so curious on how many of us enthusiasts/DIYers use torque wrench?
I have a fairly good one, but I just don't bother.
Thanks.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
I have a set of three, 1/4" 3/8" and 1/2" drive. I use them to torque everything to spec. Saves a lot of time by not dealing with snapped bolts and stuff coming loose.
Active
Past
Oka
Post by Oka »
RickHaleParker wrote: 15 Oct 2017, 06:09 I have a set of three, 1/4" 3/8" and 1/2" drive. I use them to torque everything to spec. Saves a lot of time by not dealing with snapped bolts and stuff coming loose.
Very logical. Thanks!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I would use one for the timing belt tensioner, a head bolt, or a subframe bolt. And definitely for the wheel lugs, until I got the feeling how much to torque it. For others just by feeling, bolt size and safery concern degree.
Been thanked: 4065 times
If you use a torque wrench for a week of jobs along side a ratchet, you can get a feel for what your
wrist - 5-10 ftlbs
elbow 20-35 ft lbs
Shoulder 50-60 ft lbs (perfect for lug nuts with lubrication)
Body - more
will deliver. Most applications torque is not critical - one place where it is is when Volvo tells you to torque to 80 ft lbs then 60 degree angle turn. Dont short cut those - beg borrow rent steal - ok, don't steal. Borrow mine if you are in the NE.
Old age gives you the experience to feel a fastener reach the combination of head friction, thread friction, and bolt stretch where you won't break anything by over torque. All my broken fasteners are from seized steel in Al with age and oxidation rather than over tightening.
I salute you guys who torque everything to spec - well done.
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
I have so far only used my torque wrench for the driveshaft bolts on the Volvos, head bolts on my '69 Mercedes, and the CVT transmission on my Honda scooter. Everything else I do by feel, and never had anything snap off or come loose. Also, I recently read somewhere that you must always return the torque wrench to '0' after use, i.e. Don't leave it set to any other setting, for it to remain accurate.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Only use them on head bolts and camshaft sprocket (CVVT type).
The rest is pure experience based on metallurgy, size of fastener, depth of reach, my current muscle tone and thread pitch. My mind is just like an IBM computer from the sixties...... :P
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
My friend uses it for everything, then runs into situations where the torque wrench won't fit.
Sooner or later it's best to learn what it feels like.
j-dawg
Year and Model: 1999 V70 T5
Post by j-dawg »
If even application of force is necessary - head bolts, cam cover bolts, wheel bolts - then yes. Smaller screws going into aluminum is also a good use of a torque wrench, though for some things I've just gotten used to not going full gorilla on it (intake manifold, thermostat housing, etc).
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Depends what it is. If it's something that might result in a leak or disabling the car if not proper/even then, yes, absolutely I use a torque wrench. Except the lug nuts-- if you've taken enough wheels off you get a pretty good feel for it without the torque wrench as long as someone hasn't done something dumb like put grease on them. I found that a 7lb sledge with about 6-8 inches of swing on the T-bar is just right for wheel lugs. For steel on steel suspension parts held on by bolts in the 15-18mm size range I 'swing harder' and its about right. Except if aluminum is involved. Then I look up the spec and use the torque wrench. You don't want to risk weakening or stripping out threaded aluminum on higher torque applications. And you will if you're not careful.
