Diesel Volvos are a little different to gasoline powered ones, but in the V70 versions of the D5 not hugely. If you assume the drawing of the accessory component bracket, and assume it is correct as seen above, it is the same as on any 5 cylinder gas engine. On this particular issue the problem is one of chemistry between metals.
Heat may help as the aluminum will expand quicker than the steel bolts. A quick shock with a hammer when hot should be enough to loosen the bolts.
Good luck!
Volvo V70 Diesel 1998 WAGON Topic is solved
- Has thanked: 2207 times
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 674 times
- Been thanked: 164 times
Hy there,
Well, at the end, assembling parts of several informations and the success is at the "rendez-vous"...Big applause to my wife Géraldine who has known have a different view on my engine, (I talk about the car of course...).
There is a screw, a 6 pans Allen, hidden under the cover of the timing belt, which was necessary to unscrew to free the accessories mounting.
A big up also to all of you who got involved in my issue. Sincerely "Merci ".
As you can see.
The 6 pans screw
The way to unscrew it: Do consider this topic solved.
As you can see.
The 6 pans screw
Glad you got there in the end. Not sure how much we helped, but hopefully the encouragement and support helped at least! Well done.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Wish we had Diesels
So glad you were successful.
- Been thanked: 4071 times
De rien, Manovlov!
