I have ordered and received Volvo part number 31201104 https://www.volvopartswebstore.com/prod ... 01104.html
This is the actual kit that I ordered from ebay https://www.ebay.com/itm/VOLVO-HANDS-FR ... Be&vxp=mtr
And am wondering if this is all I need to install bluetooth on my XC90. I have seen other addendum parts to this kit mentioned (mute option, etc) but no real direction on what is needed and in what circumstance. I have the PREMIUM (not the High Performance) sound system.
Also, once I have this kit installed, do I need to have VOLVO reprogram the stereo?
Volvo factory bluetooth add-on - do I need to have Volvo reprogram the stereo?
soundquest
- Year and Model: v70 2005
soundquest
Bump. Anyone???
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
No, once you get it in, it sits in line from the amp to the speakers.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
It's unlikely anyone would know for sure. My '06 S60 has it installed, but it was in the car when I bought it.
On mine, wiring wise, it is effectively placed between the radio/external amp (if equipped) and the speakers. When inactive the BT module bypasses itself via internal relays so that the entertainment system powers the speakers directly. When active/talking the audio system is disconnected from the speakers (literally) while the BT module uses it's own internal amplifier.
Motorola customized these for a couple different OEs with vehicle specific wiring harnesses to make them plug and play without cutting any wires. There was also a consumer version, model# IHF1000, that could be wired to virtually any car either with vehicle specific harnesses sold by Motorola or by cut/splicing wires.
By design it's a pretty universal device. I found a pdf manual for the generic IHF1000 version because I was having trouble figuring out the voice commands to clear everything (phonebook, paired devices etc) from the PO. The 'mute option' appears to be when using it standalone with a separate speaker/not wired to the factory speakers. In that case you need to run a wire to the 'cell mute' trigger on the back of the radio.
- 1962 Views
Last post by soundquest
- 1596 Views
Last post by chrism
- 1724 Views
Last post by a3inverter
- 1453 Views
Last post by GMJim
- 13 Replies
- 5430 Views
Last post by wrybread
