1999 V70 Full heat only on drivers side , manual climate control MCC
readallthebooks
Year and Model: 1999 V70
Post by readallthebooks »
was driving home on the freeway with the A/C on and out of the blue the driver's side vents went to full blast heat. the passenger side is fine. i tried rotating the drivers side temp dial back and forth maybe 20 times and it's still full heat only. shut the climate control on and off again a few times and i disconnected the battery and crossed the terminals for a minute and that didn't reset anything to make it work. what's the next step in troubleshooting?
note: manual control version
Has thanked: 2200 times
Been thanked: 1852 times
If it was an 850 I'd say it was the cabin temp sensor, but the V/S/C 70's only use one for both sides. There are no reasons I can think of where the RHS is not connected in some way to the drivers side. The flaps are all connected. As the temp is the only issue I would suggest the most likely issue is the ECC unit has failed. They are usually sharp enough at a junkyard and simple to swap out. Wear gloves to remove the ECC unit as there are some sharp edges in there. I find wiggling the unit up and down helps to release it from the dash.
readallthebooks
thanks. i should note this is the manual control version. if i found the automatic version in the junkyard would that swap in as a direct replacement or no?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
No.
Mcc & Ecc are NOT interchangeable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
readallthebooks
Uch, bummer. looks like the mcc version is a needle in a haystack
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
scot850 wrote: 22 Oct 2017, 16:40 If it was an 850 I'd say it was the cabin temp sensor, but the V/S/C 70's only use one for both sides. There are no reasons I can think of where the RHS is not connected in some way to the drivers side. The flaps are all connected. As the temp is the only issue I would suggest the most likely issue is the ECC unit has failed. They are usually sharp enough at a junkyard and simple to swap out. Wear gloves to remove the ECC unit as there are some sharp edges in there. I find wiggling the unit up and down helps to release it from the dash.
+1 on being careful during removal. I took one out without covering my hands and ended up looking like I had attempted to slit my wrists.
I'm not very familiar with the MCC version, but is it not cable operated? It could be just a cable has come loose, I had assumed your car was ECC as most here in Canada are.
readallthebooks
hmm maybe? i don't really know much about it myself either. i searched around but couldn't find anything about cables coming loose... maybe a piece of plastic broke somewhere? it seems weird that it defaulted to full heat.. i guess i'd expect it to remain at whatever setting it was on before it presumably broke.
Been thanked: 4065 times
All our cars use full flow heater cores and AC evaporators so the temperature is adjusted by blending the hot and cold air. I'm sure you just have a simple mechanical failure of the blend door which is just admitting hot air to the driver side. Slide under dash and follow the cables to the system and look for things fallen off.
If it disappears into the jungle , you might have to take the dash off yo deal with it. Ugh, 10 hours of work.
I'll look and see if I can find MCC info in Alldata for the superior 1999 model, practically perfect in every way...
It looks doable from inside car... :D
readallthebooks
started to dig into this. pulled the kick panel and carpet and found the cable had come disconnected from this lever here. i put it back on but there's something further up the line causing it to bind, so i took it back off and just wedged the blender to be fully closed to hot air. i pulled the radio because it takes like ten seconds, but the cable mysteriously disappears somewhere and doesnt go directly behind the radio. gonna leave it like this for a minute until i have the time to pull out the climate control head unit
