Solved / can be deleted
gltmannen
Year and Model: 1994 850
Post by gltmannen »
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
I wasn't able to open the first link/image - this may be something about where I am at.
Odds are the arm on the back of the control panel snapped where the cable is inserted that goes to the drivers side temp control cable, or where the cable hits the arm at the mixer. I'd remove the cable from the control panel and attempt to move it manually.
If it is snapped at the control panel then I'd just attempt to procure another or see if you can modify what you have with an epoxy such as JB-Weld. Remember that the cable should be able to turn without restriction to avoid it snagging and potentially eating through the cable jacket.
If it doesn't move at the mixer box while moving the cable then you may require a new cable.
gltmannen
Post by gltmannen »
wizechatmgr
That I don't know. Possibly through the glove compartment but one of the folks with this year & model will likely respond in the next 8-14 hours. Still 02:00 here on the east coast of USA.
wizechatmgr
Hey @Abscate do we know of anyone that has a vehicle that is similar to this that may be able to give this new member some assistance?
readallthebooks
Year and Model: 1999 V70
Post by readallthebooks »
i'm going through the same thing on my v70 with mcc, its the same design with a different faceplate, but i haven't gotten to tear into the control unit yet. if this isnt solved by then i'll lend a hand
wizechatmgr
Found a video of Robert's that may assist...
Has thanked: 1502 times
Been thanked: 3817 times
MCC was pretty rare here and we can't search three character phrases, either.
The cable can be accessed from under the dash though and it's pretty simple
