Solved / can be deleted
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
I wasn't able to open the first link/image - this may be something about where I am at.
Odds are the arm on the back of the control panel snapped where the cable is inserted that goes to the drivers side temp control cable, or where the cable hits the arm at the mixer. I'd remove the cable from the control panel and attempt to move it manually.
If it is snapped at the control panel then I'd just attempt to procure another or see if you can modify what you have with an epoxy such as JB-Weld. Remember that the cable should be able to turn without restriction to avoid it snagging and potentially eating through the cable jacket.
If it doesn't move at the mixer box while moving the cable then you may require a new cable.
- wizechatmgr
That I don't know. Possibly through the glove compartment but one of the folks with this year & model will likely respond in the next 8-14 hours. Still 02:00 here on the east coast of USA.
- wizechatmgr
Hey @Abscate do we know of anyone that has a vehicle that is similar to this that may be able to give this new member some assistance?
readallthebooks
- Year and Model: 1999 V70
i'm going through the same thing on my v70 with mcc, its the same design with a different faceplate, but i haven't gotten to tear into the control unit yet. if this isnt solved by then i'll lend a hand
- wizechatmgr
Found a video of Robert's that may assist...
- Been thanked: 4068 times
MCC was pretty rare here and we can't search three character phrases, either.
The cable can be accessed from under the dash though and it's pretty simple
- 443 Views
Last post by RickHaleParker
- 318 Views
Last post by SorryDog
- 591 Views
Last post by leoxdeng
- 249 Views
- 461 Views
Last post by MoVolvos
