Did you know? 🤔
850 wagon base, turn, hazards and high beam blows fuse
TerrDawg
Year and Model: 97' V90/98' S90
Has thanked: 6 times
Been thanked: 13 times
United States of America
TerrDawg
Post by TerrDawg » Fri Oct 27, 2017 11:35 am
I bought this 96' 850 wagon a few weeks ago, my daughter just started driving and thought it would be perfect. It had "the water fell outta the engine" problem per the owner, when it jump started, I offered $300 and it was sold, patched it together and drove it home to Northern California ... No turn signals tho.
I ditched the hub caps and got the 5 spoke blade style, threw on a rear wing, factory Thule style roof rack, cleaned it up, and it runs great except the turn signals. After reading here, I got 3 hazard flashers from PnP, each one blows the 13 fuse, if I leave the hazard switch out, the high beams work, but no turn or hazards...
I tore apart the front looking for a pinched wire, there is evidence of a repair but no obvious issue, I read more and cleaned all bulb sockets, still nothing, I did a battery disconnect / reset alarm etc, nothing.
Actually, it worked for about 5 minutes before blowing the last time... Goin crazy here. The turn/ high beam indicator (the part on the steering column) seems to be working fine, does that have a known issue? - I've also tried the loose ignition mechanical thing and that's not it.
I also took the hazard unit apart, it looks nothing like the one pictured in the thread with the same issue, so any help would be awesome TIA
Terry
These users thanked the author TerrDawg for the post:
jsn9839
96' 850 Wagon blue, non-turbo
97' V90R white 190K w/ Peg's
98' S90 black 245K
98' S90 white super clean!
tryingbe
Year and Model: None
Has thanked: 0
Been thanked: 22 times
tryingbe
Re: 850 wagon base, turn, hazards and high beam blows fuse
Post by tryingbe » Fri Oct 27, 2017 12:57 pm
There is most likely a short.
I'd take out all the turn signal bulbs out on all four corners of the car and see if it blows the fuse when you use turn signal. If it doesn't, then put the bulbs back in one at a time and see which bulb blow the fuse. Then you can at least isolate the circuit.
These users thanked the author tryingbe for the post (total 2):
matthew1jsn9839
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 7 times
Been thanked: 137 times
Canada
Post by scot850 » Fri Oct 27, 2017 2:41 pm
Also check the actual turn signal switch itself. It may have a internal short or broken wire after 20+ years.
These users thanked the author scot850 for the post (total 2):
matthew1jsn9839
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
TerrDawg
TerrDawg
Post by TerrDawg » Fri Oct 27, 2017 3:24 pm
Good thinking, Thanks !!
jsn9839
98' S90 black 245K
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 20 times
Been thanked: 37 times
BEJinFbk
Post by BEJinFbk » Fri Oct 27, 2017 7:16 pm
Any sign of a towing package?
These users thanked the author BEJinFbk for the post:
jsn9839
TerrDawg
TerrDawg
Post by TerrDawg » Sat Oct 28, 2017 10:17 am
Another good possibility, there is no hitch now but I'll crawl under it later today to look for remnants- I used to do installs dunno know why I didn't check that already
jsn9839
98' S90 black 245K
kahl
Year and Model: 2000V70XC
Has thanked: 0
Been thanked: 7 times
kahl
Post by kahl » Sat Oct 28, 2017 1:16 pm
There is a wire harness that goes through the roof into the tailgate. Inside the wire harness the wires are known to stretch and break causing shorts.
These users thanked the author kahl for the post:
jsn9839
TerrDawg
TerrDawg
Post by TerrDawg » Mon Oct 30, 2017 8:34 pm
I took all four corners out, unplugged the hazard flasher and fuse blew instantly, I'll check the roof wiring (didn't know about their running above) but was thinking its in the column at the turn indicators high beam switch btw, no sign of hitch, thanks again very much for the help - on a separate note, I bought an S90 that is the cleanest I've seen, runs great, but water in the oil will post in the 900 section
jsn9839
98' S90 black 245K
BEJinFbk
BEJinFbk
Post by BEJinFbk » Mon Oct 30, 2017 11:13 pm
Might also be worth digging around for signs of an aftermarket alarm.
Chasing shorts is always a treat... Maybe this will help! :mrgreen:
96 850 Turn Signals and Hazard Lights.pdf
These users thanked the author BEJinFbk for the post (total 2):
TerrDawgjsn9839
Has thanked: 211 times
Been thanked: 686 times
Trinidad & Tobago
Post by abscate » Tue Oct 31, 2017 5:09 am
Go here first for shorts. Most of the wiring on the Volvo is top shelf, this is one of the very few weak spots on wagons
If you have more than one thing blowing, and no evidence of wiring hacks, this is a 95% certainty
These users thanked the author abscate for the post:
jsn9839
