I have searched threads for days now. I need your help... Please!
Ac seized...
Can't find a used one locally...
Tried to run a shorter sepentine belt, it worked until I needed to run my lights and wipers. Doesn't charge I guess that way because alternator running opposite direction.
Seems like there would have to be a bypass pulley that would work off a similar set up on a different car. Hoping some one out there knows something. I can't afford a new ac compressor right now and I'm spending plenty on cab rides.
Thank you, Eric
Any bypass pulley? Ac seized...
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I have the AC from my '98 and it was still working when the car died a while back. Don't know the cost to ship it your way, but anything is possible.
Shane
The AC is free for shipping cost.
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Has thanked: 2199 times
Are 98 and 99 AC compressors the same? I know the alternators aren't and are mounted differently.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Search ipd volvo belt without ac
obayha
I am not sure. I was just throwing it out there as I have stuff I do not need laying around the basement taking up room.scot850 wrote: 01 Nov 2017, 11:18 Are 98 and 99 AC compressors the same? I know the alternators aren't and are mounted differently.
Someone should know.
Shane
1998 V70 T5 331,000
I didn't have access to Vida at the time. -98 is listed as Part # 8601533, and 99- has a list of up-changed part numbers with the most recent being 8603132. If I recall the mountings are different.
98 and 99 are different, compatabity unknown
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Shane, I might be all over that compressor. I have a bad one in my '98.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
As noted, there is a bypass belt routing and short belt that can be run to take the AC compressor out of the equation and preserve your ability to operate the car.
'95 855 auto (sold)
'95 855 auto (sold)
E Showell, I read on the 2000 the computer needs the alternator and compressor for the alternator to charge properly. So I was concerned about that. And if you have more info on the bypass belt routing, that would be handy. Shorter belt runs under alternator on spins opposite direction. So, not charging and battery light flashing, today I was hoping I could have enough angle for the belt to move the alternator the correct way and jumped it....It ran for a bit with no flashing battery light and the sputtered out. Also, left some grooves on the flat side of the belt (from the pulley). Found a used one, hopefully it is the right one. If not still need any input. Thanks. Eric
- 1460 Views
Last post by bmdubya1198
- 7118 Views
Last post by oragex
- 1421 Views
Last post by XC70Rider
- 86 Replies
- 23180 Views
Last post by herbakis
- 5428 Views
