2005 S60 Manual Climate Control
asummers
Year and Model: many
Post by asummers »
Hello, My daughter's 2005 S60 with the manual climate control is acting up. The fan speed/on/off knob seems loose and the fan runs when it wants to. Fiddling with the knob does not change its speed. Gratefully this week during the cold morning it has ran and been able to defrost the windshield and heat the car. But, this warmer morning it did not seem to run. I am guessing that the knob is made into the circuit board inside the climate module, since there doesn't seem to be a replacement switch available. Is it as simple as going to my local junk yard and getting a similar climate unit, remove the old and plug up the new used one? Thanks, Alan in Knoxville, TN
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
At the very least disconnect battery and put key in pos ll when connecting again or you could end up with an airbag service warning .
There's always a gotcha even if it's simple.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above. As for the issue, I would rather try first a new cabin blower unit (used but find one that doesn't show rust in the center of the fan blade and look for one with the controller on it, Ebay has a handful of these). I would then try a used climate unit as the second option.
Been thanked: 4065 times
It might be hard finding manual climate (MCC) parts in PnP , that option wasn't popular here
