AW55-50SN woes-easy to repair? Topic is solved
This topic is in the MVS Volvo Repair Database » Repairing a AW55-50SN Transmission in a 2001 V70
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
This is what my filter looked like. Also had the classical whining pump noise from being starved.
Worth to mention though is that this was caused by broken hard parts that caused one clutch pack to burn up.
Edit:
It took a long time before any codes showed up.
BMW 540i 2002
S70 Base 2000
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
kallekula wrote: 06 Nov 2017, 14:43 Edit:
I didn't get any transmission codes at all. Just a towtruck.
kallekula
Post by kallekula »
precopster wrote: 06 Nov 2017, 16:04
Yupp that's what I got too finally. Glad we have premium AAA 😆
BMW 540i 2002
S70 Base 2000
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
precopster wrote: 05 Nov 2017, 15:17 TCC solenoid is one of the smaller ones. Do you have documentation to identify it?
SLU controls TCC: 200 mA unlock, ~500 mA - controlled slip, 1A - fully locked.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Bravo, nice work! Your risk was rewarded
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Thanks Mecheng. The big tell-tale was that I could get it going again with compressed air down the cooling line. Without that I would have scrapped it.
I've had to retighten the clamps at the filter a couple of times and top up fluid due to small leaks but otherwise all good.
vt9000cse
Year and Model: 2003 Saab 9-3 Linear
Post by vt9000cse »
Well now it's not working again but at least it moves. I got 60 miles of driving with it. But now it's stuck in 2nd gear and transmission errors P0731 and P0733 and P0734 1st, 3rd and 4th gear range errors.
I recently purchased an actual full flow inline transmission filter that I will put in line with the transmission cooler. And then I'll also try another drain and flush and perhaps punch even more holes in the internal filter.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
vt9000cse wrote: 10 Nov 2017, 07:58 Well now it's not working again but at least it moves. I got 60 miles of driving with it. But now it's stuck in 2nd gear and transmission errors P0731 and P0733 and P0734 1st, 3rd and 4th gear range errors.
Personally, I would find a used transmission or sell the car. No amount of fluid is going to fix the hardware damage. Why put more money into it.
85 GLH, 367 whp
00 Insight, 72 mpg
As you didn't have a transmission track record as I did with mine it sounds more like it needs to be opened up for parts replacement.
If fluid has good flow you should stop suspecting the pump. Mine has enough pressure that it can't be blocked off by placing a thumb over the hose with engine running.
22volvo
Year and Model: 2004 v70
Has thanked: 2 times
Post by 22volvo »
Folks,
Early in the thread it was asked if a solvent was available for getting stuff out of the transmission.
Documented in the following thread was my experience.
viewtopic.php?f=9&t=37906&p=340409&hili ... vo#p340409
My 04 V70 now has 217K on it and still running strong.
Disclaimer: I just maintain my own vehicles and educate thru this and other forums before tackling uncharted territory. I have no connection to the solvent mentioned in thread, just resolved my issue. It would be good if someone else attempted the procedure to see if it is a generic repair for fluid/contaminate/sludge related problems or just a one off in my case.
Thanks to those that share their problems and solutions.
2004 v70 2.5T 286K miles.
