850 '94
Thanks in Advance
It takes a 36 mm socket, a can of PB Blaster, and hopefully an air impact wrench. If you don't have an impact wrench get a 3/4" drive socket and a 3/4" drive breakover bar. You will need to add a 4 or 5 foot pipe to extend the breakover bar and then you will likely need to jump on the pipe to break it loose. Soak it with the PB Blaster overnight before you even try.i need to remove the hub nut and i dont know how??????
Looks like there are some trick susp. mods.
