1999 v70T5M P80 serpentine belt life, interval, actual practice
Been thanked: 4068 times
Ok, I just noticed the replacement interval on the serpentine belt on my 1999 is 60k
I put my first replacement on at 137k, now I'm at 200k
How often are people replacing serp belts in practice!
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
When they snap or start shredding. On my last car I was replacing them every 50k miles due to wear and cracking. That car wasn't the quality engineered product this one is, so you may get significantly more life.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Those belts usually give you quite a bit of warning before they let go. Certainly enough to get to the parts store for a replacement, likely enough to get you wherever you're going for a few months. It's cheap enough that you might replace it "just because" during a timing belt job, but durable enough that you could neglect it without incurring disaster.
Has thanked: 2203 times
Been thanked: 1852 times
If it breaks, it can take out the the timing belt cover as it flails around and the TB with it. This has happened, be warned!
Check the belt for cracks appearing and when you see them get a new one. Mileage is not the only determining factor, heat, environment and oil/crap leaking can reduce the lifespan.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
When I find them on crack. lol I seen a YouTube video where a guy sprayed something on his and claims it last 700,000+ miles.
wizechatmgr
rspi wrote: 10 Nov 2017, 18:59 When I find them on crack. lol I seen a YouTube video where a guy sprayed something on his and claims it last 700,000+ miles.
I think I've seen that video before. Believe he was using Vinyl/Rubber conditioner.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
When i see tiny little cracks on the lines.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
wizechatmgr
What do you plan on doing with that used belt? =p
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
A broken serp (new but "off brand" (not OEM)) a couple years ago took out my timing (skipped time) on my C70 as it wrapped itself around the crankshaft. ... broken belt = broken engine. Do the math.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
Primary reference for SERP belt for 1999- and P2 models
Part numbers. 9458376, 30731808, 9471981
MFG Numbers
6DPK1841, 6DK1841
