Ok, I just noticed the replacement interval on the serpentine belt on my 1999 is 60k
I put my first replacement on at 137k, now I'm at 200k
How often are people replacing serp belts in practice!
1999 v70T5M P80 serpentine belt life, interval, actual practice
- Been thanked: 4068 times
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
When they snap or start shredding. On my last car I was replacing them every 50k miles due to wear and cracking. That car wasn't the quality engineered product this one is, so you may get significantly more life.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Those belts usually give you quite a bit of warning before they let go. Certainly enough to get to the parts store for a replacement, likely enough to get you wherever you're going for a few months. It's cheap enough that you might replace it "just because" during a timing belt job, but durable enough that you could neglect it without incurring disaster.
- Has thanked: 2203 times
If it breaks, it can take out the the timing belt cover as it flails around and the TB with it. This has happened, be warned!
Check the belt for cracks appearing and when you see them get a new one. Mileage is not the only determining factor, heat, environment and oil/crap leaking can reduce the lifespan.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
When I find them on crack. lol I seen a YouTube video where a guy sprayed something on his and claims it last 700,000+ miles.
- wizechatmgr
I think I've seen that video before. Believe he was using Vinyl/Rubber conditioner.rspi wrote: 10 Nov 2017, 18:59 When I find them on crack. lol I seen a YouTube video where a guy sprayed something on his and claims it last 700,000+ miles.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
When i see tiny little cracks on the lines.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- wizechatmgr
What do you plan on doing with that used belt? =p
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
A broken serp (new but "off brand" (not OEM)) a couple years ago took out my timing (skipped time) on my C70 as it wrapped itself around the crankshaft. ... broken belt = broken engine. Do the math.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Primary reference for SERP belt for 1999- and P2 models
Part numbers. 9458376, 30731808, 9471981
MFG Numbers
6DPK1841, 6DK1841
MFG Numbers
6DPK1841, 6DK1841
