no teeth on starter, 1997 Volvo S70 T5, won't turn over by hand
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 13 Nov 2017, 07:30 The 1997 S70 problem ......
First thing I noticed. Maybe that's the problem...
Marvel Mystery Oil works wonders for freeing up a seized engine. Worked great in my Saab.
It sounds to me like you were just hitting a compression buildup from the plugs being in. Perfectly normal.
You can look at the flywheel through the starter hole obviously, and I believe there is an area under the transmission where you can see it. I'd definitely like to see a pic of this starter, though.
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
Since the car was donated to you I would bet my paycheck it needs a new PVC system. Before you change the starter, take off the intake manifold and renew the PVC and while you have the intake off replace the starter. It will be much easier. Also, while you are in there inspect your power cable. Would be a good time to replace while you have it all apart.
bmdubya1198
shaker_chi wrote: 13 Nov 2017, 20:26 Since the car was donated to you I would bet my paycheck it needs a new PVC system. Before you change the starter, take off the intake manifold and renew the PVC and while you have the intake off replace the starter. It will be much easier. Also, while you are in there inspect your power cable. Would be a good time to replace while you have it all apart.
Agreed. Safe bet that the PCV is clogged up.
That power cable can be a pain, and you’ll be able to easily trim and move the old one to a safe place with everything opened. You’ll have to run the new one alongside the main harness cover unless you want to spend a weekend cleaning up wires. I chose the easy way and ran it outside the cover.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
rileyman wrote: 13 Nov 2017, 17:01 ok...it is a 1998 according to the book in the car, was going with what my brother told me about it being a '97...I put a wrench on the crank and it turns over, albeit you feel resistance at compression, went and took the plugs out and it turns over easily...what is this pinion thing mentioned?...I will take a picture of the starter, no teeth, and a chunk out of the housing; but I am not sure how to post it. Accessories spin also, PS, ALT, AC....What could have possibly happened, could the car just need the starter replaced?...
Use for full editor when you reply and look for attachments. Click on attachments and you can attach a file.
Sounds you need a new starter.
85 GLH, 367 whp
00 Insight, 72 mpg
nickelghandi
Year and Model: 1998 Volvo S70 GLT
Has thanked: 14 times
Post by nickelghandi »
Replace the starter with a new one from IPD or elsewhere, and give it a crank. It should fire right up. If instead of turning over, it screeches, grinds, or whines, then you may also have damaged teeth on the flywheel.You will know it right off the bat. I haven't done a starter on my 98 Volvo S70 GLT yet, but I just did it on a Ford F-150 and the starter teeth were gone, but the flywheel was still good. It makes sense that manufacturers would make the more easily removable starter cog out of softer metal than the flywheel. I would hope Volvo was at least as smart as Ford in this regard.
Let us know how it goes.
-Nick
rileyman
Year and Model: 240 1992
Post by rileyman »
alright, put in a new starter, crossed my fingers and it started right up.....noticed a few more things needing attention, the antennae won't retract all the way, sticker for the timing belt says it was done at 140,000, there is 208,000 on the car, the nipple on the coolant reservoir is snapped off.....all things to keep in mind, but it was a free car, what the heck.... Thank You all for your input....
Has thanked: 2209 times
Been thanked: 1852 times
Well one major thing to strike of the repair list! The engine now runs. The other stuff is not overly hard, and if you can change a starter motor the rest should be within your abilities!
Good Luck!
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Now time to look into replacing fluids and hoses next =)
2023 Lexus RZ450e -66k
Has thanked: 1611 times
Been thanked: 4072 times
You are due for a new timing belt at 70k, so 210,000 for you, but don't sweat it too much. It can wait a few months or thousands of miles until you get to it. I ran one of mine 35k past time, and my " stare death in the face Beetle" is 5 years overdue.
