ABS Sensor ohm readings
MarcM
Year and Model: 2005 S60 2.5T AWD
Been thanked: 3 times
Post by MarcM »
Long time, no post. Anyone have the info on what the ABS sensors should read on a 2005 S60? I searched, but it gave me info for 850s, etc. I was able to get the rear seat up to get to the connectors for each side. One reads 18 Mohm (seems high) and the other is open (RR). Testing it on car no movement.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
Has thanked: 1611 times
Been thanked: 4075 times
They should be a few thousand ohms. You need to disconnect the plug to measure to isolate
The open circuit one has a problem.
MarcM
Post by MarcM »
Thank you abscate. I disconnected under the rear seat. The open one was an error on my part. All 4 read 17.7-18.2 Mohms. I'm going to pull them from the hub assembly then retest. I'm hoping there's not a $450 XeMODex rebuilt unit in the future.
2005 S60 2.5T AWD
IPD mods:
Marc...put your part number up and I'll compare mine. Maybe I'm quoting from my old guy memory from my bastard 99 which might be a P80 number. I'll check my 2005 P2 and report back later today
I doubt all four sensors are bad so I'm guessing they are ok if the all read 18 M Ohm
MarcM
Post by MarcM »
Since I replaced the CV joint shafts in the front... thinking I broke something or the shaft bolt in the end loosened up and shaft sliding in/out putting the magnet & sensor out of alignment. I just discovered a major issue, so at this point I'm abandoning that fix. :(
2005 S60 2.5T AWD
IPD mods:
