IPD sale Volvo Parts
V70xc wont crank Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 42 times
Been thanked: 173 times
Trinidad & Tobago
Re: V70xc wont crank
Post by abscate » Sat Nov 18, 2017 2:41 pm
Once plugs are out. Put a straw full of engine oil into each cylinder, replug and give it another try
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
oragex
Year and Model: S60 2003
Has thanked: 34 times
Been thanked: 46 times
Canada
Post by oragex » Sat Nov 18, 2017 8:26 pm
There were a few cars with mangled crank pulleys gear, it would show as some play at the pulley if I'm not wrong. Just another possibility
2003 2.4i S60 automatic 125k miles
jking4020
Year and Model: 1997 850, 2001 v70xc
United States of America
Post by jking4020 » Sun Nov 19, 2017 12:44 pm
Ill try that today thanx. And if the crank pulley was mangled/stripped all the other components wouldnt be turning. As they are.
jking4020
Post by jking4020 » Sun Nov 19, 2017 2:40 pm
Ok... Did the straw full of oil deal. Still nothing. At first try it sounded like there was compression but no normal cranking. I think its dead. 😒 Was a good car. Anyone know where the inertia relay/switch on this model is? 01 v70xc 2.4 t5 turbo. P2 i believe.
jking4020
Post by jking4020 » Sun Nov 19, 2017 2:41 pm
And the plugs looked ok. Not wet. Normal wear from when i changed them less than a year ago.
Trinidad & Tobago
Post by abscate » Mon Nov 20, 2017 5:11 am
Did you get some compression readings??
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
jking4020
Post by jking4020 » Mon Nov 20, 2017 3:37 pm
Not yet. Gonna check camshaft sensor
jking4020
Post by jking4020 » Tue Nov 21, 2017 10:17 am
Sensor works. Ill get compression tool today.
jking4020
Re: V70xc wont crank  Topic is solved
Post by jking4020 » Tue Nov 28, 2017 11:29 am
Ok so car died. Bent valves due to bad timing belt tensionor pulley. Belt slipped and.....r.i.p. got a newer 04 xc70 though that im gonna buy and use the old car for parts. Thanx for all the ideas.
Return to “Volvo V70 & XC-70 (2001-2007), S60 (2001-2009)”
Who is online
Users browsing this forum: No registered users and 21 guests
