bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I found an ECU intake hose at the PaP today that was in perfect condition. $0.95 near mint used beats out $15 new any day!
Also grabbed another shift knob and egg crate to add to my collection... if anyone is interested in either, let me know!
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Drove the V70 to work, had a kerflunk while leaving my driveway - realized the only thing left that could cause it happens to be the torque tube bushing. Looks to be a pain in the rear unless you have the right size c-clamp and a small piece of plate steel.
Found either I lost, or someone helped themselves to, the little piece of plastic that goes around the front tow/tie-down hook.
Have figured out that thus far this old car has had a better track record in my first year of owning it than my previous model year 2007 car. Quality lasts...
2023 Lexus RZ450e -66k
ChadLee
Year and Model: 1998 V70
Has thanked: 6 times
Post by ChadLee »
Front struts, springs, spring seats, strut mounts and sway bar end links. Did it after work on Friday and even had time to monkey with a loose belly pan! I am a total novice, but was able to do the job with help of a local shop putting the struts and springs together. Air would have been nice, but not needed. I put in Sachs struts and they seem a little loose, but a world better than it was.
1986 245 DL, 1989 244, 745 Turbo and 1981 245 DL - gone to new homes
1989 245 GL - Wife's daily driver
1989 245 DL - In the works for a daily
1998 V70 - Daily driver
2001 V70 - Next project
Has thanked: 1613 times
Been thanked: 4075 times
I discovered today you get a lot more boost when your vacuum tree line goes to your CBV rather than the elephant hose from the MAF to the turbo, and your CBV no longer is holding off your turbo because it was connected to the elephant hose.
With wizechtmgr help, definitive diagnosis that the NoisyPig has a bad AC clutch bearing - can see the wobble.
Kahl has very nicely sent me a short belt to diagnose - I will decide between used or new AC compressor over winter.
Also temperature override DOES defeat AC on the 1999 ME7, even in the DEFROST position.
:D :D :D :D
bmdubya1198
Yeeeaaah..... you kinda need a real vacuum source going to the CBV.
I mashed into it at 3000 rpm and almost broke my seat mounts. I probably should go back and reset my wastegate
So wcm and I had a good week, he restored my boost and together we found a 1/8 of a turn to get his passenger side axle bolt torqued (later typeM10 bolt) stopped his Vida ABS brake error message....pending a week of driving check. We also caught pulley wobble on the AC compressor, so hopefully that will quiet the Noisy Pig 1999
StubZz
Post by StubZz »
Replaced my upper engine mount in my 1998 V70 2.4L base model wagon :D
brunocerous
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I picked up a silver MT 2000 V70 last week for cheap, and started with the rear brakes / parking brake. Things were pretty rusty back there, but everything went off without a hitch! Need to readjust the parking brake after a short test drive, but otherwise a marked improvement.
RR wheel on a 2000 V70
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Heard about this one from the Marcomm department, Bruno. Watch those rear rotors to see if the get shiny as you drive it to make sure those calipers are free.
Next time you order parts , add some bleeder screws to the order and replace them all, after you push 500 ml of fluid through each one of course.
