Inatead of adding the Lucas Transmission Fix I added about 4 ounces of Stop Oil Leak in the ATF reservoir before I realized the mistake.
2003 Volvo S60, 2.4L Turbo with 199k. No transmission issues before adding the incorrect fluid aside from a slight stutter into 3rd. It's been doing this since I owned it (6 years).
No known transmission fluid changes before I bought it. How screwed am I?
Lucas Stop Oil Leak instead of Stop transmission
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I once added half qt of motor oil to my tranny in a Volvo 740 before I realized it wasn't red.
Never changed it and it didn't bother it.
But, why are you adding that stuff?
What a relief to know. I have owned a number of foreign cars over the years and always used Lucas products. HD synthetic oil stabilizer with Mobil 1 synthetic oil with oil changes and Lucas fuel additive with 93 octane only. I used the Stop Oil Leak one time a few years ago because a mechanic told me I was leaking motor oil (untrue). It's sat on the shelf since until today I grabbed the wrong bottle.
The intermittent "stutter" into 3rd gear at 35-40 MPH is a mystery though. It only does this at low, in-town acceleration. Highway and back roads no problem. It's done this since I've owned it. That's when I bought the Lucas Transmissions Fix last year to try it out. It just started doing it again recently, so I decided to add more today and added the Stop Oil Leak instead. I need her to make it to at least 300k, so as you can imagine I was a little freaked out especially with winter coming and all.
- Year and Model: Lots
- Been thanked: 128 times
What ATF reservoir are you referring to? There isn't one!!
You just made your power steering leakproof!!
- jonesg
It's common for shift bump in very cold startup, if it's doing it when warm you might want to read the recent thread about saving these cars from the junkyard with a simple procedure to eliminate the internal fluid filter and installing an external filter.Amk20155 wrote: 24 Nov 2017, 16:57 What a relief to know. I have owned a number of foreign cars over the years and always used Lucas products. HD synthetic oil stabilizer with Mobil 1 synthetic oil with oil changes and Lucas fuel additive with 93 octane only. I used the Stop Oil Leak one time a few years ago because a mechanic told me I was leaking motor oil (untrue). It's sat on the shelf since until today I grabbed the wrong bottle.
- jonesg
Here's the thread, interesting read, you ought to do atf fluid change at the least. It could solve the problem . If not... read on.
viewtopic.php?f=9&t=82841
- 1734 Views
Last post by sacricide
- 1313 Views
Last post by volvolugnut
- 10 Replies
- 4625 Views
Last post by tryingbe
- 2484 Views
Last post by jimmy57
- 870 Views
Last post by misha
