Missing rear intake cam seal
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
I found this on my 2001 V70 2.4T. There is no oil seal on the rear of the intake camshaft, just the plug which you removed. This is very model specific however, so it may not be the same for others.
Cars I've owned:
- prwood
My concern is if there is a drain hole on the other side of the seal, you may be blocking oil from properly draining.
Cars I've owned:
- Been thanked: 4071 times
No seal on my 1999. New cap does not seep oil.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
No problem leaving the seal in place, some mechanics like the double coverage. There are NO moving parts outside of the seal so no problem.
- prwood
My assumption was that the engine was designed to operate without a seal in that location, and that putting one there would put it out of spec (in terms of the force required to turn the camshaft with or without the seal in place). But maybe the spec includes some latitude in that area... or maybe I'm being overly analytical.
Cars I've owned:
- 736 Views
Last post by petrikah
- 710 Views
Last post by kallekula
- 1502 Views
Last post by iRenaissanceMan
- 2093 Views
Last post by vtl
- 17 Replies
- 5505 Views
Last post by cn90
