1998 S70 Which Manual Transmission [gear] Oil to use?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I've used only Amsoil ATF in both of my MT's, the 93 850 since 2008. When I bought the cars I drained/filled with Amsoil to flush, then after 500 miles another drain and fill. Shifting is smooth in all weather. The slight first gear whine in my 93 went away with the Amsoil.
Volvo doesn't make its own; they probably contract with Amsoil.
baxtex
Year and Model: Volvo S70 99
Post by baxtex »
Hi, I happen to have this oil: http://www.mpmoil.nl/products/index.php ... anguage=en
as I was about to change the oil on my Mercedes automatic gearbox. Then I sold the car before I did it, so I have about 10 liters of this stuff.
Now I need to replace the oil in my Volvo S70 gearbox (M56) and so I was thinking maybe I can use this oil instead? It was quite expensive, so I think it's good quality but I'm not sure what specifications it has. Don't know if anyone here can confirm or deny? I have emailed the company, not gotten answers yet.
Has thanked: 1611 times
Been thanked: 4075 times
I would use a gear oil, not a light ATF oil in your M56
Sell the ATF on eBay to someone else.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
I agree with abscate here. That ATF does not say it is GL-4 compatible (or even GL-5/GL-4 backwards compatible). I wouldn't put it in our transmissions... It'll either be too slick, not slick enough, or it'll introduce something that will cause wear.
Retired:
2015 Volvo S60, T5, 85K
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I use Volvo oil.
I've used Redline and Mobil. No difference in shift quality so since I get Volvo parts for cost +10%, and no shipping... I use Volvo fluids since they're right around the corner from me.
Time saver!
Escargot
Year and Model: 1998 V70 T5
Has thanked: 2 times
Post by Escargot »
For those who have replaced their MTF, did you find that you needed a 3rd bottle to fully top off the 2.1L capacity? Or is the remaining .1L usually made up by fluid that doesn't fully drain? I have 2 bottles of Genuine Volvo 31280771 and am deciding whether to purchase a 3rd before I start the job.
You can Run it 100 ml short. In the summer,it will expand anyway. You could always filter your old stuff and top,off
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Virtual duplicate of above post. Deleted.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Escargot wrote: 26 Aug 2020, 15:46 For those who have replaced their MTF, did you find that you needed a 3rd bottle to fully top off the 2.1L capacity? Or is the remaining .1L usually made up by fluid that doesn't fully drain? I have 2 bottles of Genuine Volvo 31280771 and am deciding whether to purchase a 3rd before I start the job.
I have replaced mine but don't recall needing a third bottle. If memory serves me right I had a little left over even.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
theWIFES_S70
Yes, I could only get 2L in there, too.
Retired:
