1995 Volvo 850 Turbo TRAC and ABS light
winter4w
Year and Model: 1995 Volvo 850
Post by winter4w »
would like to say hello and that I will be new to these forums.
We got a 1995 Volvo 850 Turbo with TRAC and ABS lights on. I did look around and people say the ABS module will fail however that's for the 1996 and up. I have not found anything for 1995. I plugged in my ODB2 scanner and got no codes. The car has had those lights on for a long time now just thought it would be good to look into and get fixed.
Thanks
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Agreed -- it is less likely to be a cracked solder joint in the module.
You might have a damaged sensor or dirty rings as described below for the '95...
viewtopic.php?t=19483
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
On my 95 those lights are intermittent but its pretty common for them to come on. I've cleaned the ABS sensors with no luck. Let me know what works for you, maybe it'll help me too.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
You have a dtc box under the hood that will tell you what's wrong. Pull the codes and see what they say.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
winter4w
Post by winter4w »
jreed wrote: 23 Nov 2017, 05:49 Agreed -- it is less likely to be a cracked solder joint in the module.
I'll have to go give it a try thanks :). Anything you recommend me using to clean it? Hope that this will fix it lol
polskamafia mjl wrote: 24 Nov 2017, 03:25 On my 95 those lights are intermittent but its pretty common for them to come on. I've cleaned the ABS sensors with no luck. Let me know what works for you, maybe it'll help me too.
Will do I hope cleaning them fixes it if not I would guess the sensor might be bad or the ABS module failed.
Matty Moo wrote: 24 Nov 2017, 06:44 You have a dtc box under the hood that will tell you what's wrong. Pull the codes and see what they say.
Any scan tool you recommend I use to scan for those codes? I did try my ODB2 scanner however they showed everything was good.
Thought I should share this too the lights sometimes won't come on once you start the car however once you start to drive they come it.
Matty Moo
Post by Matty Moo »
No.
You actually have a box under the hood that will tell you the codes. It is your dtc box.
2000 s70 GLT
2014 Ram
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Diagnostic panel under hood.jpg (71.52 KiB) Viewed 3445 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
winter4w
Post by winter4w »
Ok here are the codes I got ...
213
214
141
142
Any ideas?
misha
Post by misha »
Which port....A3?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
winter4w
Post by winter4w »
misha wrote: 30 Nov 2017, 01:38 Which port....A3?
Yes the A3 port
