1998 V70 Remote Start AFTERMARKET Topic is solved
CEBirnley
Year and Model: 1998 V70 Base FWD
Has thanked: 13 times
Post by CEBirnley »
I am interested in installing an aftermarket remote start. Please advise on solid system options. I am not looking for anything fancy, mainly just to start the car. Please advise.
Has thanked: 2203 times
Been thanked: 1852 times
I have used Viper systems on 2 P80's. One was the more basic 2 way with remote start and the other is an immobiliser with remote start. They were expensive once you add in the inevitable add-ons for automatic trans and install. Cheaper one was about $400 CDN the more expensive nearer $700. Both have re-chargeable remotes. Our labour rates are often higher here too. Try places like Best Buy for options/deals. Not sure who else has options there in US.
There are plenty of systems out there and up here they get m any deals on them including install this time of year.
If I was keeping the V70 basic I would put a simple system in as neither remote likes to lock the car. Both are ok opening it though.
Been thanked: 4068 times
SWMBO recommends the Honeywell one , fits all cars.
After I start her car, she says “Honey, well done!”
CEBirnley
Post by CEBirnley »
Neil - I had the Vipers in two other vehicles and yes, very nice! The V70 is “my” car which means I don’t get many “bells and whistles”, because I’m “Dad”. So just looking to get a remote starter. KISS is my goal.
Abscate- must be part of the “Honeydo” Line...
Don't forget about Dad! He needs toys too. Kids are hardy, let them put on a few more layers and learn to use manual locking!
Good luck with the hunt.
splats
Year and Model: 1996 850 Turbo Wagon
Post by splats »
My '96 850 came with a Code-Alarm (aquired by Audiovox (now Voxx)) remote start system already installed. I don't have anything to compare it to, because it's the only one I've ever had.
Things I like about it:
- it was already installed!
- starts the car from inside the house and thru 2 walls (maybe 80' away?)
- batteries last a very, very long time (5 years-ish?)
- remote lock/unlock, too
- climb in, insert key and turn to on position to drive away. If you touch the brake without the key in, the engine dies (simple anti-theft).
Thing I don't like about it:
- difficult, blinking-light-style configuration (with nested menus, even). Kind of a pain, but it's an older system and I've only had to make changes twice (maybe not such a big deal...).
Good luck.
CEBirnley
Post by CEBirnley »
Neil - well, we are kind of already doing that, the lock actuators only work about 20% of the time so they have to wait for me to unlock my door anyway. The old man here is getting soft. I am basically looking for a way to start in the morning before I head out to work and then hit it again before I head home at the end of the day.
Splats - Great stuff! This is all I am really looking for, is straightforward. Thank you for the information.
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
As somebody whod prefer not to install a remote start myself bigger issue than brand/type is the shop installing it IMO. If you ever run into problems no shop usually wants to deal with these systems unless they did the install originally.
Of course if you’re handy enough to install and fix them that’s a non-issue, but for those of us who aren’t quite there Id recommend a shop that’s been around for a long time and has a good reputation.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
One other idea - what about a circulating block heater instead? I had one on a heavy duty timer on my old convertible. Had it setup to start 15 minutes before I had to leave for work. Literally unplug it, start car. Go. Heat coming from the vents instantly.
Is the goal the "instant" heat or the defrost, or both?
CEBirnley
Post by CEBirnley »
wizechatmgr wrote: 03 Dec 2017, 23:34 One other idea - what about a circulating block heater instead? I had one on a heavy duty timer on my old convertible. Had it setup to start 15 minutes before I had to leave for work. Literally unplug it, start car. Go. Heat coming from the vents instantly.
Ideally both, but if I had to choose, it would be defrost...I’m husky so I don’t mind being cold, but driving w an ice covered windshield is a little challenging. ;)
