Misfire code after heavy acceleration but only twice this year
LOB
- Year and Model: 855 GLT 2.5T
- Has thanked: 10 times
- Been thanked: 16 times
I've got code P0305 (fifth cylinder misfire) once and P0300 (multiple misfires) once on two separate occasions this year. The check engine came on, on both occasions, when I was cruising at 55 mph for hours and then made a kickdown acceleration. The engine hesitates and doesn't gear down as anticipated. This has only happened during these circumstances and everything in the ignition is newish except the single coil (850 GLT -97 , LPT). I've never heard a single misfire on this 90000 mile well maintained engin and it drives like new except on these two occasions. Does anyone now why I get the misfire code? Real problems on the horizon?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
By chance, do these happen right after or during precipitation?
LOB
No, it happened yesterday in dry cold weather. It took five months since I cleared the code to reoccur.wizechatmgr wrote: 04 Dec 2017, 04:38 By chance, do these happen right after or during precipitation?
- Has thanked: 2205 times
Could be a bad plug wire or spark plug has a hairline crack. When were the sparkplug wires last replaced? I have seen the #5 wire get trapped under the plastic cover and it can then short out. However, I would expect that to be more frequent than that.
When was the fuel pump and relay last replaced as well as the fuel filter? Have you checked the fuel pressure?
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I had the same issue with my 98 T5. Turned out I had a bad spark plug wire. Take a look at yours, I believe there is a date code on each. Mine were original to the car, so I replaced them with the 8mm IPD version and replaced the plugs with O/E
Volvo plugs. I haven't had the problem since.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You could also have a minor intake manifold gasket leak. Spray around there with starter fluid and see if the idle changes.
LOB
Thanks! The wires are 18 months or so (OEM, "Bougicord") the spark plugs are about the same age, Volvo original (albeit from a Chinese vendor at AliExpress, I don't(didn't) think the market is big enough for counterfeit Volvo sparkplugs to be worthwhile/profitable. The packaging looked 100% original and I know by experience that the Chinese hardly ever can counterfeit logos and packaging 100% authentically.(?)). I'll check the manifold gasket with starter fluid and if the wires are bent somehow.
- 2062 Views
Last post by Clemens
- 1262 Views
Last post by dksoutha
- 1360 Views
Last post by Nevada1906
- 2255 Views
Last post by An R rated life
- 9 Replies
- 1931 Views
Last post by RussB
