Piston skirt slapping crankshaft making jackhammer sound
Steve99s70t5manual
Year and Model: 99s70 t5
Post by Steve99s70t5manual »
So my 99 s70 t5 has a ticking g sound that turns out to be one of the piston skirts hitting the crankshaft and the most cost effective way to fix it is shaving down the part of the piston that is making contact with the crank. Any feedback on this procedure and if it can make further problems.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
How did you confirm this? Might want to find out what caused this to occur, since it obviously developed somehow. You might want to have the rest of the engine examined for damage before you start putting money into fixing it.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
The two shouldn't be making contact. There is another issue present...
2023 Lexus RZ450e -66k
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Probably rod knock.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 2210 times
Been thanked: 1852 times
I have unfortunately heard of rod knock several times on these engines. Can't say the cause as I don't know the cars personally or the owners, but I have suspicions it may have to with either poor maintenance or driving style in most cases.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Wouldn't that be a twisted conrod or is that not even possible? Conrod bearings are pretty easy to remove and check while the sump is off in any case. You may be able to do this without head removal.
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I bought a good-looking 850 turbo wagon that had a "tinking" sound in the engine. After confirming that it wasn't a lifter and having a couple of rebuilding techs listen to it, we concluded it was likely a bent rod. It was. I pulled the head, sump and pistons, cleaned things up, replaced the bent rod and other things while I had it apart. Check out the link below that documents the process.
Engine rebuild tutorial pdf
If it's a bent rod, the skirt is "tinking" on the counterbalance as the piston is BDC when the counterbalance is at its highest point. Normally, those 2 parts run very close together so it doesn't take much of a bend to bring them in contact.
The problem with running it like that is the rod has lost its longitudinal strength and if you load it too hard it could break and you lose what might otherwise be a decent engine that could run another 100k miles. Also, it seems likely that the metal to metal contact would eventually damage the bearing on that journal.
My bearings were in excellent condition, even at 200k miles, so I reused them on the advice of 2 rebuilders. The rod bolts are reusable as long as they're still 50 mm.
If you need parts for your engine, you could try Crankshaft supply in Minneapolis. They had a large inventory of used parts, including the connecting rod that I needed. Part prices were reasonable. I also had them boil-bathe the pistons and put on new rings, they looked like new.
https://www.manta.com/c/mmc15zz/cranksh ... ompany-inc
The engine runs beautifully.
Good luck getting it solved.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
If the hose from turbo control valve to wastegate or the hose from turbo outlet to TCV cracks the boost will go HIGH. Rods will bend and then the piston tavels is offset downward where skirt and crank counterweight touch. Also aggressive wastegate adjustment can do this too. I did it to a 98 V70 of my own by forgetting to hook up the hose to turbo outlet one time. The car ran R E A L L Y good too. The check engine light came on and when I stopped and rolled down window I heard the tapping noise. It was too fast as tappet rattle is once every two revs where skirt tap is once every rev.
