brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Tonight I replaced the driver-side mirror I bashed into my trash can, and the busted passenger-side mirror I foolishly had replaced with flat glass instead of the convex, wide-angle glass.
It was dark, so I only took a pre-installation picture.
Headed side-view mirrors, 1998 V70.
abscate wrote: 06 Dec 2017, 04:03 You can leave the battery connected when you charge ,B.
I also put a shot of lube into my hood latches once a month to keep them working smoothly.
Do you still have SAS on your V70? Search for SAS delete to see how to get rid of this before your next inspection hassle
I wasn't sure about leaving the battery connected, and I'm notoriously cautious with anything electrical, but good to know. Just hope there's no next time!
What kind of lube do you use for the latches?
The SAS delete is on my list!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
watchmaker_of_death
Year and Model: 850 '93
Post by watchmaker_of_death »
Today on my '93 850 I replaced the front diskbrakes and did a renewing of the brake fluid. And unblock the backseat seatbelt.
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Completed the jury rigging of the rear defrost. Hasn't worked since I bought it and last night was the first snow storm...
There is a lack of continuity on the wire. For now this will do the trick. Is it proper? No. Is it the ideal solution? No. Will it get the fricking frost and ice off? You bet!
2023 Lexus RZ450e -66k
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
wizechatmgr wrote: 10 Dec 2017, 14:34 Completed the jury rigging of the rear defrost. Hasn't worked since I bought it and last night was the first snow storm...
Sometimes you just have get inventive, nice job!
I finally installed the new OEM radiator on my 98' XC on Saturday. At the same time I also replaced the starter with a Bosch rebuilt and the lower transmission cooler hose. Then the snow tires went on, right in time for the snow.
Everything looked good and there were no leaks after test driving the car yesterday, so I took it to work today, which I haven't done in a really long time.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Ouch... that picture of the trunk wiring is making my PTSD act up... I hate that harness. My trunk lock still doesn't deactivate my alarm upon unlocking. I repaired a few wires, cleaned them up all nice with some corrugated wire covering, closed the trunk, and it worked. Next day I try it again, the alarm goes off. I've given up on that.
Which reminds me I'm still wondering why my cruise control isn't working. It stopped working for some reason a while back, then last month on my way to a car meet it magically started working again. Next day it stopped and hasn't worked since. Maybe it's trunk wiring related, who knows.
Has thanked: 1614 times
Been thanked: 4078 times
bmdubya1198 wrote: 11 Dec 2017, 08:27
Yes it is related to trunk wiring failures at least. I actually found a non fail safe mode for my cruise on my 99 when the trunk wiring took out my immobilizer, it also inhibited the clutch switch from dropping the cruise.
bmdubya1198
Looks like I might have to go back in there. Joy...
Well, at least I really don't use my cruise anyway.
540 mile grind from upstate NY to Boston, PVD, and back
God, I love the P80 seats. MassPike was slippery going out but 65 on the way back.
wizechatmgr
New headlights arrived. One good assembly, one broken - adjusters. New new driver's side on the way.
These will look great on the '99 and have to throw more light than the ones I have. One side is tipped upwards, the other downwards. The car has googlie eyes and it sucks at night.
Especially if turned right side up before installation...
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
Tried to fix my ECC system in my '00 V70xc.
Had no aircon coming on, but automatic heating worked fine. Especially annoying when trying to demist the windshield.
Cleaned the interior temp sensor a week ago, but kept getting the blinking orange lights on startup.
Built a 'led flasher OBD reader' as suggested for older models. Was not able to read codes but think I succeeded in resetting the system. Cleaned the sensor again. Now all seems to be well again :) no more orange lights and A/C kicks in as normal! Hope it will stay this way. Any others that did a similar fix?
This is the led code flasher that I built. I was not able to read codes, probably only works on OBD-I and not OBD2. Think I did reset the system by depressing the button for 5 seconds.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
