94 960 ECT sensor
94 960 ECT sensor
I have a 1994 960 with 251,000 miles. For a 17-year-old, I would say I care way too much about it. I recently swapped the head gasket due to an external leak, and actually enjoyed doing it because it was straightforward with little frustration. However, what is frustrating is the ECT sensor issue I have been having. Recently, the CEL came on during a cold start with the ECT code, so i bought a new one, swapped it out, and the code keeps coming back after a reset. So I figured that maybe the connecters were just being pushed back in their housings due to volvo’s crumbling connector insulation; but I removed the housing and could see that the pins were, in fact, connected. It idles very rough after prolonged city driving and bucks in 4th gear when you give it just enough gas to not downshift. I don’t believe it’s a wiring issue considering I replaced the entire harness when I did the head gasket. There also doesn’t appear to be corrosion on the connectors. Any help or input is appreciated.
- RickHaleParker
- Been thanked: 958 times
The ECT is connected across pins 20 & pin 30 of the ECM. Pull the ECM and check the connection there. Sometimes just pulling and reinserting the ECM will make a problem go away for good. Best to do so with the battery disconnected.
jimmy57
- Been thanked: 320 times
ECT for ECM is on the back of the head for that year model, not the one by thermostat. 1996 is the year they used one by thermostat. Also the insulation crumbles on the connectors on harness side plug for one on back of head. That could let the connectors slip back and not connect well.
- RickHaleParker
Keep in mind, a thin layer of oxidation is enough to cause problems. Never hurts to clean them with electrical contact cleaner.
- RickHaleParker
If the ECT code does not come back, disconnecting and reinserting the ECM did what I hoped it would do.
Any diagnostics codes from the Transmission Control Module? Have your ran test modes 1-4? (selector cable in hole #1)
If you don't already have it ... 1994 Volvo 960 Transmission Diagnostics: http://caunter.ca/volvo960/ce14807.pdf
- RickHaleParker
Good to see you fond the problem.
