2005 S80 2.5T, 180K
For the second year in a row, as winter sets in I get a P0101. Engine runs fine, no other symptoms. I've cleaned the MAF and filter.
I'm wondering if it's possible that there is a very minor vacuum leak somewhere, which appears in cold weather when the rubber/plastic contracts. Any ideas/suggestions?
P0101 in cold weather only
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
It would be helpful if you had VIDA, as the generic P0101 can be either Volvo's "ECM-1210 Mas air flow (MAF) sensor - Flow Too High" or ECM-121B Mass air flow (MAF) sensor - Flow too low".
In both cases, the ECM calculates how much the airflow ought to be, then it sets the code if the actual measured flow is outside of that amount +/- a range.
From VIDA, in both cases, possible causes are:
- Contact resistance or oxidation in the mass air flow (MAF) connectors
- Air leakage in the intake system
- Blocked intake system
- Damaged mass air flow (MAF) sensor.
So, looking for vacuum leaks is a good start.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- Roger_850T
I would look in two places. First, some of the big air hoses can fail, especially if you have a lot of miles and your turbo is leaking some oil into the intake system. I would feel all around them, and check that they feel firm (not squishy) and don't have any tears or holes.
Second, I would check out the little vacuum elbows. I'm not sure exactly where they are on your engine, but they can get soft and fail, also, and cause issues.
I'm trying to think why it would only give you the error code when the outside air gets colder. Maybe it's as you said, a hose getting stiffer with the cold and not sealing as well. Nothing else extraordinary comes to mind - I'll let you know if I think of anything.
Roger
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- RickHaleParker
- Been thanked: 980 times
"I'm wondering if it's possible that there is a very minor vacuum leak somewhere, which appears in cold weather when the rubber/plastic contracts. Any ideas/suggestions?"
Marginal leak in the intake manifold gasket that is only sufficient when the gasket is cold ... metal contracts when cold.
When the engine is stone cold, fire it up and spray burst of starting fluid around the intake manifold gasket. If there is a leak, it will suck in the starting fluid and your hear the engine surge.
Active
Past
Past
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I would also put the throttle body on the suspect list. The internal nylon gears could possibly be worn. In my experience with this type of failure it acts up in cold weather and will set DTCs for the MAF. The ECU seems to ignore the TPS which indicates a part open throttle plate that isn't returning fully to the idle position, or sticking at certain points and not allowing the throttle plate to open as much as the ECU commands. But it does set DTCs for incorrect air flow through the MAF under these conditions.
However, you do want to thoroughly rule out intake leaks and the sensor/wiring before looking into this if you haven't already.
- Skymongrel
- Year and Model: 2023 XC90, S80 2007
- Has thanked: 20 times
- Been thanked: 23 times
So my 2006 XC70 is doing this exact same thing! In fact this is the third year that I've had it pop up during a cold snap. It usually goes away. Sure would like to solve it once and for all. I've read some good tips here but was wondering if you ever resolved your problem?
Thanks for any help you can offer. BTW I was taking the car in to get inspected and this P0101 popped up!! Can't win.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
RHP, is there a sensor associated with reporting P0101?RickHaleParker wrote: 10 Dec 2017, 21:41 "I'm wondering if it's possible that there is a very minor vacuum leak somewhere, which appears in cold weather when the rubber/plastic contracts. Any ideas/suggestions?"
- RickHaleParker
P0101 is based on calculated air flow vs measured air flow from the Mass Air Flow Sensor when the long term fuel trim is above or below a set value.
Active
Past
Past
